(Boost problems)what causes oscillation or surging on a procede or jb3 tuned car?
05-12-2009, 05:24 PM | #1 |
///M Specialist South Shore BMW
772
Rep 7,108
Lately my procede has been giving me some oscillation (I think thats the term) under heavy boost after around 4000 rpm's. Im on stage 1 with dci and 93 octane with ut ranging from 64 to 74. I have the latest canbus maps and lately its been doing it more. Its on and off and happens when I first start driving the car with ambient temp ranging from 45-65. As soon as it seems to go away after the car warms up more it comes back again under full throttle in higher gears. Ive tried all sorts of different settings and it seems nothing changes other than getting more powerful to less powerful with changes in user torque settings. Any one with knowledge (vendor or non vendor) can chime in and tell me what might be causing it or explain what the engine is doing while its happening I'd appreciate it. Its getting annoying lately and it seems since canbus came out my car hasnt been driving so good all the time. Its the first time I can say my procede is inconsistent. This was the reason I sold my jb3 and now Im having these problems again.Makes me want to not run a tune at all. Any input would be greatly appreciated.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
05-12-2009, 06:11 PM | #2 |
772
Rep 7,108
btw...no issues with the car at all when stock. I want this to go away
05-12-2009, 06:20 PM | #3 |
Modder Raider
753
Rep 8,633
Drives: M3
Are you getting fluctuation of boost at full throttle?
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
05-12-2009, 06:24 PM | #4 |
772
Rep 7,108
05-12-2009, 06:32 PM | #5 |
Modder Raider
753
Rep 8,633
Drives: M3
Mine is doing the same thing but it does it every time I floor it.
I'm curious if either the wastegates aren't closing all the way or if they are closing too much. Are you hearing any ticking sound at all? I just purchased a rear actuator and will be installing it this Friday because I think that it's the cause of my fluctuation.
05-12-2009, 06:59 PM | #6 | |
772
Rep 7,108
05-12-2009, 07:17 PM | #7 |
Moderator
322
Rep 5,493
I've had a similar problem recently, which spiralled into over-boosting on constant part throttle. Flashed the car back to standard, still went into overboost. Thought initially it was the downpipes because they were the last mod on the car, but discounted it because removing the precats shouldn't have any increase in boost pressure - should be the other way round. Checked the wastegates and actuator arms for tolerance, flat spots, restricted movements etc - no problems there as they are both new.
So I narrowed it down to the boost control valves. I replaced both of them, reinstalled the car, and hey presto completely even boost, no over-boost whatsoever, and that's regardless of whether the car ECU is stock or flashed.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
05-12-2009, 07:21 PM | #8 | |
772
Rep 7,108
05-12-2009, 07:51 PM | #9 |
126
Rep 993
Drives: F85
i've also noticed the fluctuating power but i'm on JB3. Thought I heard a slight ticking sound a few weeks ago but haven't heard it since. 52k miles and it just started happening a couple weeks ago....
05-12-2009, 07:54 PM | #10 |
772
Rep 7,108
Is your warranty up? Just curious, Im debating extending the warranty because it is sooo expensive. Im going off topic in my own thread...lol
05-12-2009, 08:38 PM | #11 |
126
Rep 993
Drives: F85
I got the BMW Extended Warranty. Just don't feel like uninstalling the JB3 and taking it in until I get a better idea of what it is thats going wrong with it....
05-12-2009, 08:39 PM | #12 |
772
Rep 7,108
Im the same way. I wont bring it in until something serious or obvious is messed up with it.
05-12-2009, 09:43 PM | #13 | |
184
Rep 2,841
Didn't realize they were accesible enough for a DIY FWIW, I don't get throttle oscillation where the car lunges back and forth, but I do see a bit of boost wobble on the boost gauge which I think might be normal as Shiv stated in another thread that he doesn't tune just boost, but rather he tunes for the volumetric efficiency of the motor. However, I am experiencing an occasional loss of ooomph, usually in 3rd or 4th gear. This was reported on another thread by Edo as power just fading away on a gear change into 4th. I find it happens to me too....but then symptoms disappear on the next pull.....so it's kind of random. I'm speculating that perhaps it's throttle closure due to overshoot on the boost target sometimes. While in 2nd gear, the pull is very strong and constant. On a gear change, the boost becomes unstable momentarily (the spike at shift point) and maybe it's overshooting target and causes the throttle plate to close up in order to get back onto target?? But I have no idea what I'm talking about....I'm just a bit paranoid. |
05-12-2009, 10:27 PM | #14 |
60
Rep 2,314
05-12-2009, 10:30 PM | #15 | ||
Modder Raider
753
Rep 8,633
Drives: M3
05-12-2009, 10:32 PM | #16 |
60
Rep 2,314
I was about to suggest diverter valves. I don't know which to go with though - forge or RR. I'm wondering if using the stock rubber piping is sufficient (Forge), or if I should try the RR route.
05-13-2009, 12:20 AM | #18 |
Member
28
Rep 344
The tuners are using a PID algorithm for closed loop boost control. There are gains for the proportional, integral, and differential terms that are likely set based on data gathered from various vehicles. These affect the loop response and stability but may not be ideal for all vehicles because of mods, factory variations, etc. Would it be possible to allow end users a limited gain adjustment range for one or more terms to dial in the loops for individual cars?
Present - 2016 340i, Alpine White, Black, M-sport, 6-spd, Track Handling, Tech pkgs
Past - 2011 E90 335i, Alpine White, Ivory, Sport, Premium, Steptronic Past - 2008 E90 335i, Titanium Silver, Dakota Grey, ZSP, Steptronic, 6FL, Wagner FMIC, Bilstein B12 Pro-kit, M3 control arms, SS F/R brake lines Last edited by kentgbr; 05-13-2009 at 12:54 AM.. |
05-13-2009, 12:32 AM | #19 |
394
Rep 3,161
This seems to be a very common problem i would think. I have had this issue since the dealer installed my new turbos and did not set my wastegates up correctly. I then tightened the wastegate and it did get better but i too saw it with the RevII and with the JB3. I explained to shiv what i was seeing and he emailed me a test map that did somewhat address the issue so i dont see why this cant be fixed or at least somewhat adjusted with software.
If you are running a RevII and have a rattle please PM me. |
05-14-2009, 03:38 PM | #20 |
Moderator
322
Rep 5,493
The two boost control valves are small - getting to them is a pain though. Have to get to the actuators and turbos from below, which means removing the downpipes. Car has now done 1000 miles with the new valves and it's brilliant
05-14-2009, 04:50 PM | #21 |
Vishnu Powered
68
Rep 2,205
pics? or better yet point it out on realoem.
2008 335xi Sedan | Titanium Silver | Black Dakota
PROcede v5 | Vishnu Exhaust | BMS DCI | AR Catless DPs | Helix FMIC | Stett Charge w/ Tial BOV | MORR VS8s | KWv3 |
05-14-2009, 05:55 PM | #22 |
772
Rep 7,108
the problem is so off an on. Some pulls are perfect. After a bit of driving without using much boost and then going WOT in 3rd or 4th at around 3-4k rpm's then it happens again. smooths out again after a few more pulls. Im tired of this and might remove the procede. My procede was perfect for so long and now it sux
