05-12-2009, 10:28 AM | #1 |
Alpine Master
111
Rep 1,310
DIY Request: Change 6MT, differential lubricant
I'm coming up on a year and 17000 miles on my 1er, lots of long trips on the beast, and am looking at replacing the 6MT and differential oils before I begin a 10,000 mile road trip in June. The only problem is I can't find any sort of guide on doing the fluid changes for the 1er. I know Berk and other tuners have changed the fluids. Could anybody post up a DIY for these critical maintenance tasks?
Alpine White with Taupe Leather 135i, Sports Package, Heated Seats, Comfort Access, iPod Adapter
Fastness: http://www.1addicts.com/forums/showthread.php?t=252727 |
05-12-2009, 10:44 AM | #3 |
Alpine Master
111
Rep 1,310
Most helpful. And I disagree. There just isn't a reason to change them yet; once I hit 30,000 miles I want to be a little more aggressive with my maintenance than BMW requires.
05-12-2009, 10:53 AM | #4 |
Formally known as xXxMLEExXx.
38
Rep 653
I have yet tackle the tranny, so I won't comment.
On the diff, there's just a filler plug, and no drain. You'll have to some sort of extracter to get out the old oil. Filling is easy, just fill level the car for excess oil to spill out, then plug it up. Your done. I will be doing that immediately, when I have the chance. I have 1k miles so far, I just want to get what ever metal shaving that's there.
My 1 borned on 03/26/09
On the ship...eta NJ 04/16. Picked up 04/24/09 Last edited by LemansE82; 05-13-2009 at 10:14 AM.. |
05-14-2009, 07:05 AM | #5 |
368
Rep 3,547
Auto parts stores sell simple suction pumps for a few dollars. It will be hard to get everything out this way but you can put in new fluids much easier than trying to pour thick oil with limited clearance. If you want to do it the best way, you could get two pumps and use one to extract the old fluid and one to put the new fluid in. I think I paid about $5 for one when I did this in my truck (where a change is in the service interval at about 10K miles).
Jim |
05-14-2009, 10:56 PM | #7 |
19
Rep 709
I asked my dealer to do this and they said they weren't allowed to. None of the local shops I have called (even ones with company 135s) have ever done one. I thought about doing it myself, but not at all convinced a pump is sufficient for a break-in lube change. Keep us updated!
05-15-2009, 05:49 AM | #8 |
Alpine Master
111
Rep 1,310
What kind of sealant does the diff cover use?
05-15-2009, 10:17 AM | #9 |
23
Rep 601
I think the differential bolt probably has a magnet which collects all metal shavings, I doubt you have to pop off the whole diff cover....
--2009 BSM 135i-- -Manual, Sport Package, BMW Assist |
05-15-2009, 07:33 PM | #10 |
AutoXer
34
Rep 683
Many do, but the 1 series doesn't have a drain bolt where it would work. The fill bolt is too high to to much good even if it was magnetized. Of course you could probably just use a magnet on the end of a flexible shaft and see if that works. That's probably what I will try. Hopefully there is no shavings to be found a new 1 series.
05-16-2009, 09:45 AM | #11 |
Rep 34
Um, yea. Right.
What differential oil looks like after less than 40K miles in service: http://www.dvatp.com/bmw/maintenance/e36/2009/04/18/ What happens to your steering rack if you don't flush the power steering fluid: http://www.dvatp.com/bmw/maintenance/e36/2004/08/26/ http://www.dvatp.com/bmw/maintenance/e36/2004/09/08/ What happens if you don't change your transmission fluid and filter on a regular basis: http://www.dvatp.com/bmw/maintenance/e36/2005/02/10/ With due respect, stop drinking the BMW kool-aid.
06-09-2009, 07:57 PM | #12 |
323
Rep 1,804
Any luck finding a DIY for either?
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
