Changing Injectors Yourself? New plugs Shiv found?
05-11-2009, 10:30 PM | #1 |
N54 FTW!
25
Rep 389
Just wondering if anyone has changed the injectors themselves? I've been getting missfire's on 1 & 6 and the dealer won't touch it because I've got downpipes (!)
I was planning on changing the plugs at the same time, but since I'm guessing it's the injectors that's the priority to change. I know Shiv had hinted he'd found some new plugs, but after looking back 14 pages I couldn't find the thread. Anyone know what the details on the new plugs were? |
05-11-2009, 11:19 PM | #2 | |
812
Rep 3,974
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
05-11-2009, 11:23 PM | #4 |
hi
129
Rep 1,140
dealer changed mine and new plugs because i had misfires on 1&3 but i don't have DPs best thing would be to remove your DPs, i think so.
2022 M Sport G05
Jb4, CTS catless dp, M performance exhaust, bms intake, IND goodies, Maxton kit |
05-11-2009, 11:51 PM | #5 |
N54 FTW!
25
Rep 389
HotRod: I've been reading some more threads on this. Am I wrong to suspect the injectors first? Seems like several (Shiv was one) have pointed to new plugs as the issue rather than the injectors. I know I've read of people having fouled injectors replaced, but plugs is certainly an easier and cheaper first step. What have you seen?
Alpine: Maybe, but that's not a small job, and then putting them back after the fix. |
05-12-2009, 12:25 AM | #6 | |
hi
129
Rep 1,140
btw do you have a rough idle on a cold starts?
2022 M Sport G05
05-12-2009, 12:53 AM | #8 |
12
Rep 566
05-12-2009, 01:05 AM | #9 |
93
Rep 2,339
Going back through the cobwebs of my minds I seem to remember that Shiv tried a particular plug that didn't work out.
What do I know? I'm insane.
05-12-2009, 01:28 AM | #10 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
05-12-2009, 02:01 AM | #11 |
N54 FTW!
25
Rep 389
Thanks guys,
OK, so best to start with the plugs. Btw, do you know of anyone who has taken out the injectors, or are they a special fitting to remove? I'm just guessing here that they're the unfinished metal units with the tubing, above the plugs in the pic, and look easy to access (as seen in this pic from e.n335's spark plug change DIY), but I haven't had the engine cover off yet. If I'm correct that those are the injectors, are they easy to remove/replace if the plugs don't fix it? |
05-12-2009, 07:50 AM | #12 |
50
Rep 1,137
The shop cost on the injectors is about $450 each. I don't know about special tools but I do know that the new injectors have to be coded to the car.
In my case, the car had a misfire on 2 and 5. Those 2 injectors were replaced. Less than a week later the car was back in the shop with a bad misfire. This time it was on 1 and 5 (yup...the cylinder with the new injector). My tech convinced BMW to change all 6 plugs and all 4 remaining injectors. Now it is smooth again. All that to say I think the plugs may be the bigger issue. I saw plugs out of another 335i that had been misfiring. The prongs were bent WAY out of shape. If I was you I would start by changing those first since the plugs are only about $15 each.
2010 Evo X - silver with a big, stupid wing on the back
2009 VW CC - Black/Black - with a 2011 328i on order to replace it - ED 8/1/11 |
05-12-2009, 07:58 AM | #13 |
1013
Rep 3,157
If its not the plugs then its the coil packs...your having an ignition problem not an injector problem. The factory spec on the coil packs is pretty loose and we have found them to vary greatly in quality...once you start to mod then there is no guaruntee that you will not have misfires because you might have the coils that made it through on the low end of the QC...looks like you might have two!
Former Car: '16 SUNBURST GOLD F80 ///M3--6MT/Carbon Cloth (ED Thread) Former Car:'13 SANTORINI BLUE E92///M3--6MT/Speed Cloth/ZCP(ED Thread) INSTAGRAM:@C2KMotorsports |
05-12-2009, 08:07 AM | #14 |
133
Rep 4,764
Injector = $260 part number 13537585261
Plugs = $140 with N54 socket Ignition Coil = $51 Get them from the site sponsor Tischer BMW - http://www.getbmwparts.com I would start with plugs only and see what that does. |
05-12-2009, 08:28 AM | #15 |
60
Rep 2,314
I'm curious.. aftermarket downpipes aren't exactly the easiest thing to spot. Did you actually tell them you had the dp's or did a tech spot them after diagnosing your car?
05-12-2009, 08:35 AM | #16 |
76
Rep 911
I had the misfires in 3,4,5 and 6.
BMW replaced my ignition coils and all plugs... problem solved! Especially with a tune plugs and coils gets quicker to the end of their life...
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
05-12-2009, 09:16 AM | #17 | |
76
Rep 2,304
not true, it could be injectors. to the op, just change your plugs first. if the problem persists start thinking about injectors/coils
05-12-2009, 11:48 AM | #18 |
N54 FTW!
25
Rep 389
Thanks guys.
No, they looked for the DP's. I had left the codes in so it showed the missfires, but there was also a Cat code (UR catted DP's-usually with the O2 sim on V3, but took it out before the visit), which made him look at the exhaust. I'll try the plugs, then coils, then injectors. Really, with all of the above, you may be right, might be cheaper to take the DP's out and have them fix it. But as we heard above, fixing it might take a few weeks and multiple trips. Anyway, thanks for all the help. Especially knowing the injectors have to be coded, not a DIY job. I can see why an old F1 mechanic I used to know (for Ferrari back in the 50's) always said his pick for the perfect car was a VW Beetle and a tool box, cause there's nothing he couldn't fix on the side of the road! lol |
