Meth Mixtures
05-11-2009, 04:35 PM | #1 |
Rep 142
Meth Mixtures
This weekend I will be installing my Delux Trunk Mount Coolingmist meth kit. I will be using the bigger of the two nozzles. For the people running meth on here, what mixtures do you use. I plan on tapping the bov pipe unless other have better suggestions. In my past car, i have used Boost Juice which is a 49/51 mix, however adding a couple bottles of HEET to that might be a good idea. The mods on the car right now:
dci/tbe/tune/tial bov, the meth will be set based on rpm and flow will increase with rpm/boost. Car went 116-117 on the stock run flats and i have 275 bfgs on the kosei wheels just waiting for a nice weather. Hopefully another 135 in the 11's soon, MT not auto btw about 275 drags on the back of a 135, they dont fit, I had my fenders rolled at Supreme in NJ and they STILL rub, however its a good thing the 1/4mile track isnt bumpy |
05-11-2009, 05:49 PM | #2 | |
ocasionally in crisis
52
Rep 2,358
btw, with my mods listed below, i ended up using a 375 Ml/min nozzle. snow performance says keep the mix of water and methanol at 50% each. but i read somewhere that shiv - after he saw the guy´s dyno - told the user to go up to like 75% methanol.
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
05-11-2009, 06:19 PM | #3 | |
ASR Turbos+LSD+Meth= :D
73
Rep 1,517
Drives: E92 335i
I haven't done it yet though. I still use the snow performance mixes. btw i upped to a larger nozzle (the M7) from a different company as the sizes vary too much in the snow line (375ml/min too small and 625, the next size up is too large). I only suggest doing the same midlife. you will drop your IAT's even more.
2007 335i Coupe Mods: Check the Garage |
05-11-2009, 06:37 PM | #4 | |
52
Rep 2,358
i remember now that you are the guy that shiv told to up the methanol mix percentage a few quick questions: 1/ what % methanol mix are you using for daily driving? also is that the same mix you use when racing?? 2/ also, if i buy the number 7 nozzle like you did: a/ will it fit my snow nozzle holder? b/ what approx size is it: say 500ml/min? c/ where did you buy this nozzle ?? lastly, what approx whp are you at now?? thanks
05-11-2009, 06:51 PM | #5 |
Rep 142
The kit came with 380/cc and 500cc nozzles. They give ratings for a 150psi pump, however I upgraded the pump the the 250psi and will be able to control the pressure based on rpm/boost, so i think im going to lean it out and start off with the 500cc nozzle. Unless you guys think thats too much. I have the ability to run whatever boost I want, and my track set up will be 18-19psi with racefuel/meth.
05-11-2009, 07:11 PM | #6 | |
52
Rep 2,358
i have alot more mods than you, and i am currently happy with 375ml/min nozzle. btw, according to snow performance, the 375 nozzle should be good for approx 350 -450 hp
05-11-2009, 07:24 PM | #7 | |
Rep 142
What kind of kit are you guys running and what are you tuning it with? |
