Fault Code 29F3
05-10-2009, 10:56 PM | #1 |
441
Rep 18,331
Fault Code 29F3
I am getting this code 29F3 which is..Fuel pressure sensor Electrical....I have CANbus clearing feature from the Procede, but for some reason this code is not clearing at all....I know the Canbus clearing feature works because other codes where cleared which dealt with DME not asleep while unplugging the unit out, but this one code never seems to clear at all...Anyone know if this sensor can be defective and faulty because my car is running like a champ, better than ever....There are no hiccups whatsover and smooth as can be....
Is part #7 the sensor that might be faulty? __________________ Last edited by cn555ic; 05-17-2009 at 08:20 PM.. |
05-10-2009, 11:54 PM | #2 |
26
Rep 865
Drives: 2018 F15 X5 xDrive35d
I also have this code showing up. I was able to clear it with BT tool, but after restarting the car it popped up again. The car is running perfect though.
05-11-2009, 12:07 AM | #3 |
99
Rep 6,473
[QUOTE=cn555ic;5094966]I am getting this code 29F3 which is..Fuel pressure sensor Electrical....I have CANbus clearing feature from the Procede, but for some reason this code is not clearing at all....I know the Canbus clearing feature works because other codes where cleared which dealt with DME not asleep while unplugging the unit out, but this one code never seems to clear at all...Anyone know if this sensor can be defective and faulty because my car is running like a champ, better than ever....There are no hiccups whatsover and smooth as can be....
Is part #7 the sensor that might be faulty? cn55ic, I had a similar problem when I first installed my V3.2. Don't you have the same tune also? I sent my unit back to Shiv and he said it was a corrupted file in the unit. All that he had to do was install the new firmware and reprogram the module. You might be having the same problem as mine? |
05-11-2009, 07:14 AM | #4 | |
441
Rep 18,331
[QUOTE=Bimmer This;5095360]
I will load up the firmware again to see if it will work, but I know the CANbus feature is working corrrectly because it cleared three other fault codes and they haven't come back so far, so I think the unit is working like it should... ANyone else have this problem? |
05-11-2009, 07:15 AM | #5 |
441
Rep 18,331
You are in the same boat as me, so what have you done, or you just left it as that because your car is running fine?
05-11-2009, 08:57 AM | #6 |
26
Rep 865
I just left it as it is for now. Was hopping to find an explanation and fix in one of those threads with all the BT tool codes listed, but this code is not posted there yet.
05-11-2009, 09:03 AM | #7 |
99
Rep 6,473
Mine was the same code yet acted very different. Everytime I plugged the V3.2 in, the car would not stay running. It started, stumbled, threw that code, and died. Everytime I unplugged the unit, it ran fine. Plugged it back in, same problem. Called Shiv and explained to him what's going on. He said he has never had that problem is any of these units. Told me to send it back, he installed it on his personal car and same problem. The only thing you could probably do it remove the V3.2 and see if the code sets while driving stock for awhile. Then you would really know if it is the unit or a failure with the vehicle. Just piece of mind. Just my opinion.
05-11-2009, 10:51 AM | #8 | |
441
Rep 18,331
05-11-2009, 11:56 AM | #9 |
99
Rep 6,473
#7 is a fuel rail pressure sensor which you are correct. I looked at All Data and it is showing that part at that location also. It shouldn't be too hard to replace if you know a little bit about cars. Just make sure to open your gas cap to purge fuel pressure before you take out that sensor or you'll get fuel sprayed all over your face. You will want to pull your eyeballs out because of the intense burning you get when fuel gets in your eyes. Trust me, been there. Just a warning.
05-11-2009, 01:00 PM | #10 | |
441
Rep 18,331
05-11-2009, 01:44 PM | #11 | |
Rep 40
If you PM me the last 7 of your VIn I can get the code description for you. Number 7 in your diagram is NOT the fuel rail pressure sensor. It IS the low pressure fuel sensor. It is installed at the low pressure fuel line inlet to the high pressure fuel pump. It is not easy to access, the intake manifold likely has to come off. (I have not done one without removing the intake.) if number 7 is at fault and is in fact defective your car will not run poorly. In the contrary when that sensor fails your low pressure fuel pump will be commanded on at 100% duty cycle, giving you maximum fuel delivery to your high pressure fuel pump at all times (engine running). |
05-11-2009, 02:02 PM | #12 | |
441
Rep 18,331
Can't you get that info without my vin? I am not understanding... |
05-11-2009, 02:06 PM | #13 | |
Rep 40
Your code was not read by a factory scan tool. Therefore the description may not be 100% accurate. Clearly it is not, it does not specifiy the exact part, being there are multiple fuel pressure sensors. Do you have the associated P-code? |
05-12-2009, 08:13 AM | #14 |
133
Rep 4,764
There is another fuel pressure sensor at the fuel rail. Part Number 13537537319. $60 at Tischer.
Part number 2 on this page: http://www.realoem.com/bmw/showparts...82&hg=13&fg=15 Last edited by scottp999; 05-13-2009 at 02:19 PM.. |
05-12-2009, 08:25 AM | #15 |
133
Rep 4,764
Also, they are writing the Bentley service manual for our cars right now. Please hurry and give input to things you want to make sure are covered. I posted about the 2 main fuel pressure sensors, injectors, coils, and HPFP: http://tech.bentleypublishers.com/th...34638&tstart=0
To get on the notification list when the manual is ready go here and sign up: http://www.bentleypublishers.com/bmw...35i/2007-2009/ |
04-27-2010, 12:16 AM | #16 |
62
Rep 380
Anyone have any more information on this fault code?
My car just started giving me this code, but the car still runs great. However, on cold starts, I have noticed minor misfires for about 10 seconds. Could be unrelated... |
06-24-2010, 10:50 AM | #17 |
441
Rep 18,331
To report back on this issue....I have this code like forever and it never clears but the car still runs perfect which leads me to believe its a faulty sensor....Anyway about two weeks ago I cleared codes with my Procede and the 29f3 code disappears and never returned...It been two weeks and the code hasn't come back, whereas before as soon as I clear it, it immediately comes back!! I don't know what happened but I guess it must of somehow starting to work properly again...Now all I see on my Can DME code is "0" which means no codes!!! The new V4 map 6-16 is making my car run like a champ...I know everyone says "BLA BLA BLA car is running better than before" but it truely is because now its optimizing my setting to allow me to run it to the max with my mods with different temps outside! I have the Can-clear option turned off!
12-07-2011, 07:52 PM | #20 |
441
Rep 18,331
I get this code occasionally and its seems to be just that, a faulty sensor...So far I cleared it about 10 times and it comes back once in a while...I have had this code since I first read it about 1000 miles of owning the car.
12-07-2011, 09:42 PM | #21 |
Rep 76
I just posted about this and I can't get the sucker to clear. I am running JB+ at 100% and using the BMS CAN Tool.
2008 BMW 335i Coupe - 6AT w/ Paddles - Black on Black - Dark Burl Walnut - 19"s - Aero -ColdWeather - Premium - Sport - Navigation - iPod - JB4 - BMS DCI - Michelin PSS - Dual Exhaust Mod
12-07-2011, 09:50 PM | #22 |
Take Off*
Rep 47
in the same boat, very interested to hear for a solution!!
JB4 G5 ISO, AR DP's, ER CP, Synapse BOV, AlpineMSS HID, BMS Oil Catch Can, BMS CDV... WISHLIST--> LSD
