jb3 helppppp
05-10-2009, 10:54 PM | #1 |
16
Rep 89
jb3 helppppp
i just installed my jb3 pin out and in map 0 everything is fine but once i put it in map 1-5 it says engine malfunction reduce power anyone know whats wrong and how to fix it thanks for all commentss
05-10-2009, 11:41 PM | #2 |
26
Rep 865
Drives: 2018 F15 X5 xDrive35d
You might have an older board and newer chip in it. Does your chip has all the pins, or is one missing?
05-10-2009, 11:53 PM | #3 |
ocasionally in crisis
52
Rep 2,358
if u do not get quick help here, try www.n54tech.com
or just email terry directly for support at his gmail address which can be found somewhere on the above site. good luck
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
05-11-2009, 01:59 AM | #5 |
161
Rep 7,377
seems you did not install it right... email terry, useless to post this help requests here...
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
05-11-2009, 02:48 AM | #6 |
749
Rep 2,108
something is definitely not installed right since when its on map 0 everything works fine but it only starts to give you a code when you select other maps. check all your wires and harnesses. you should email terry for a quick response and solution
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
05-11-2009, 05:44 AM | #7 |
Joint Chiefs of Staff
4918
Rep 115,980
It pretty much could be anything. Check the codes, and then email terenceburger@gmail.com with details for help!
Mike |
05-11-2009, 08:26 AM | #8 | |
52
Rep 2,358
absolutely correct because when u r on map 0, the JB3 is bypassed completely and you are totally stock. ... if you installed the CHIP yourself, did you have the small notch in the chip facing the right direction ??
05-11-2009, 11:35 AM | #9 |
749
Rep 2,108
i think thats where the problem is or he has a bad chip maybe??
05-11-2009, 11:38 AM | #10 |
333
Rep 4,632
Sounds like a bad install..Should be a simple fix, contact Terry, via email or phone and you should be good to go soon.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
05-11-2009, 11:44 AM | #11 |
26
Rep 865
If OP had it installed wrong, wouldn't he also get an error on map 0? I know map 0 is stock settings, but everything still goes to bypass through the JB unit, no? I'm not a tech, so I might be wrong...
