Help! SOS malfunction, no sound, no bluetooth, no ipod
05-06-2009, 07:28 PM | #1 |
33
Rep 321
So I got in m car yesterday and everything seemed fine. Radio turned on and everything, after about a minute there was no sound so i thought maybe the station got cut off. So i tried a different station but still no sound. Then tried the cd player, no sounds here either. Next thing i know I get an SOS malfunction alert. Tried plugging in my ipod and it didn't recognize that either. It also wouldn't connect to my phone via bluetooth like it always does. Does anyone know what would cause this. I did a bunch of searching and found some people saying it might be a TCU, not sure what it stand for, but didn't see any definite answers or anyone saying they got the problem solved.
I tried restarting the car a bunch of times, letting it sit over night, hoping it might fix itself, funny how often that happens with electronics, but nothing. Any help would be greatly appreciated, I have a 7 hour drive coming up soon and no music for 7 hours would be horrible. |
05-06-2009, 07:41 PM | #3 |
122
Rep 6,594
Get it to the dealer before your trip if it doesn't fix itself. You'll never troubleshoot the electronics in these cars yourself, unless you really know your stuff.
On such a new car, they should be bending over backwards to fix this for you.
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
05-06-2009, 10:15 PM | #4 | |
15
Rep 445
I did find some info on this being caused by an "incompatible BT phone", but this is hardly the case as mine had been working fine for almost 1.5 years since new (full BT functionality and no issues whatsoever). Oddly, the glitch showed up a few weeks after I got the car from being serviced at the dealer, during which they upgraded BT. |
05-06-2009, 10:51 PM | #5 |
Rep 76
This used to happen about once a month in my 07 335. I have always ignored it since the iDrive will reboot itself after about 20 minutes and everything will be fine again. Before my warranty expired, I took it in to have it looked at and they ended up replacing the CCC. Just make sure you bring it in shortly after the problem occurs otherwise they may not find the fault code (I have actually mentioned the problem before during an oil change but they couldn't find the fault code).
07-01-2009, 01:55 AM | #6 |
Rep 1
I have 09 328i w/iDrive, Ipod and USB in glove box and noticed SOS malfunction 1st time a few months back. I was using a unlocked Nokia E71 BT phone. I was talking on my car BT connected to my e71 when I suddenly got disconnected, iDrive rebooted etc and got SOS malfunction. Nothing worked after that associated with iDrive, nav, Radio, CD, etc. etc. etc.
Took it to Stevens Crk dealer who kept the car till evening and while returning back my car fixed, I was told that I was using an "Un approved bt phone" which blow a fuse in its circuitry. I was warned of not using that phone otherwise it will not be covered under warranty. SO, now I use a sony ericssion w350i after finding it on their approved list of phone on bmw usa website. I haven't seen SOS problem since then. BUT, the nightmare of iDrive hasn't left me. I converted all my music CD to aac format at 400 kbps or so. Uploaded them in the car hard drive. When I play music through the hard drive, each and every time I am in the car, iDrive reboots on me with a loud noise. After rebooting itself, it remembers the last song from previous reboot (not the song which was played before the noise). SO, I uploaded a small bunch of same music on my sandisk cruser 4GB and is plugged into my armrest compartment. Interestingly, I still see iDrive rebooting on me but less frequently. I have to take it to the dealer next week ( this time mtn view dealer where I bought my car... some how, Stevens crk dealer service people weren't friendly). I'll post updates soon. Has anyone seen this? things to note: Regarding music: aac (m4a) is an approved format to play. HOWEVER, there is no mention on bit rate of this file. Obviously, a larger file is likely to be culprit. If I use lower bit rate, 128 or so, it *might* work just fine. I haven't tried that yet since it defeats the whole purpose of having upgraded audio system. |
11-30-2010, 07:02 PM | #7 |
Welcome to My World!
Rep 32
Drives: 335i Metallic Silver 4Dr
I have the same problem!
I dont know what it is...most likely blew a fuse. Let me know if you know anything!
335i 4DR::Magnaflows, BMS twin intake, JB+, PRIVAT 19" ACSchnitzer Spoilers and Splitters, FULLY LOADED!!!
02-20-2015, 04:47 PM | #9 |
1920
Rep 13,122
Most common problem is the amp getting wet.
There are usually batches of this reported after bad weather. Trunk seals , Sunroof drains , and rear light seals are usually the way the water gets in . Next is the bluetooth phone Sos module failing. Any Module attached to the Most Bus can cause this failure. |
02-22-2015, 09:08 PM | #11 |
Rep 129
I had this problem as well. My problem was some water leaking in the fuse area and it blew the TCU fuse. They ended up bypassing the TCU or something. SOS light comes on when I start the car but the Audio Works no BT though. I have to look at the paperwork in the car. I got lucky and did not have to replace the TCU
E90 335i Crimson Red
Powder Coat Black Staggered CSL 18'/ BMS Intake / AC Schnitzer ACS3 Front Lip (rep) / |
02-23-2015, 10:45 AM | #12 |
Rep 31
Its crazy how they can lean on , not using an approved phone, to wash their hands of a problem. How could a non approved phone bring down an entire network?.... Sounds like its something involving the MOST ring as all devices on the ring are being brought down at the same time. If anyone's is interested in self diagnosing, there is a most loop-around connector on the drivers side kick panel, that is connected to a MOST diagnostic port. You can't use this one as it is needed there, but you can either buy one or borrow one to isolate a potential module that will bring down the network.
02-26-2015, 08:38 AM | #14 |
188
Rep 1,677
This happened to me when I tried to connect my sub amp improperly. It was simply a blown fuse.
But...in my research, I found this: This problem generally means there is something wrong with the MOST bus, here are the possibilities: "1) One of the unit on most bus is dead/non responsive a) Check BT unit, its most connection, its power connection, its fuse. b) Check L7 unit for the same as above c) Check CDC unit for the same as above d) Check HUD for E6x for the same as above e) Check any other fibre optic connected device like TV,DVD changer etc for the same as above 2) Open most bus connection If MOST port is left opened, e.g. the port for OPS (in the glovebox) somehow become loose and its connector came off, very rare but possible. 3) Broken/twisted most bus fibre optic wire Super rare but possible, if problem appeared after recent change/retrofit then look for twisted/damaged fibre optic wire Problem will be among these possible situation. Generally I have seen if power is disturbed to a most unit then it simply breaks the most ring and you get this problem. To isolate it you need to buy most bypass part from dealer and you can individually bypass each component to see if problem is due to that unit. Isolate and identify is the key to work on ring topology network."
2008 Montego "330i" /3.0 manifold /AA /Eurobox /PE /Alufelgen CS7 /Macht Schnell /Michelin PSS /XPel
"O thou afflicted, tossed with tempest, and not comforted, behold, I will lay thy stones with fair colours, and lay thy foundations with sapphires." (Isaiah 54:11) |
