PROcede meth failure protection in action
05-06-2009, 06:43 PM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Ran out of meth in the middle of a dyno run by accident (green run). Never really had guts to test this before. But I guess now we know that it works As soon as meth flow drops below the trigger point, the PROcede reacts by yanking out 4-5 degrees of timing immediately and dropping boost by 2-3psi. The engine doesn't even hiccup or ping during this process. In fact, I didn't even realize I ran out of meth. I just thought I sprung a leak somewhere and lost power Shiv |
05-06-2009, 06:50 PM | #3 |
21
Rep 551
Shiv,
Isn't pulling timing a bad way to go due to increase in EGT's ? Since boost is ecu controlled why not simply pull boost and add fuel ? Harry |
05-06-2009, 07:14 PM | #4 |
30
Rep 314
Drives: 07 BMW 335i Sedan+2 Baby Seats
Not that I know anything ... but if you didn't pull timing and you're mixture is not as "good" as you were programmed for, other very bad things could happen, no?
05-06-2009, 07:28 PM | #5 | |
1737
Rep 17,960
Drives: A Lot
Also, there is no quicker way to stop knock from happening in the case of meth failure than timing retard. That action can occur within 1 single engine revolution. Waiting for boost to drop takes much longer. Same goes for snuffing out knock with over-fueling. Shiv |
05-06-2009, 08:17 PM | #6 |
133
Rep 4,764
Amazing stuff. I can't wait for this kit to come out.
05-07-2009, 02:50 PM | #11 | |
21
Rep 551
Harry |
