BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
European Auto Source (EAS)
      05-04-2009, 10:44 PM   #1
m3larson
28
Drives: 2014 M6 Gran C 1997 M3 Track C
Trailer Tie Down advise
Has anyone trailer'd there M's? Where are the best tie down spots? Would installing the bumper hooks nd using those the best idea? How about the tire tie downs trailer companies sell? If you trailer please advise your tie down method..
The Verdict: Every other manufacturer should give up on building their own cars and just make M3s instead. -Car and Driver June 2008
      05-05-2009, 08:39 AM   #2
Gearhead999s
Gearhead999s's Avatar
814
Drives: RR Velar R=Dynamic M2C R1200GS
I think the tire holddowns are the best idea as it allows the suspension to work normally over bumps.We had tabs installed on our E30 race car to allow easy tie down put doing it that way made the car solid on the trailer but the car never moved.The 2 tow hooks that are on the car would be insufficent to hold the car down.
      05-05-2009, 01:24 PM   #3
ff1600
51
Drives: 2018 F80 M3 CP 6mt YMB/SB
The correct (BMW specified) way to tie down to a trailer is to use T-Hooks which are installed on the car by removing the jack pads (all four if you want the car to remain centered on the trailer).
http://www.tunnellracing.com/thook.html
http://www.tunnellracing.com/thookTN.html
      05-05-2009, 02:11 PM   #4
Gearhead999s
814
http://www.ctscargotiedown.com/wheel_tiedowns.htm
      05-05-2009, 03:34 PM   #5
m3larson
28
These are sweet. I am checking into them now and seeing if they will work on the E92 M3. Thank you for the advice.
      05-06-2009, 10:56 AM   #6
m3larson
28
Has anyone used these? I guess these go in where the jack stands mounts are inserted. However I don't see how to remove the jack stand mounts.
      05-06-2009, 01:45 PM   #7
ff1600
51
BMW has again made difficult what was simple. The jack pads I have removed in the past were held in place by two screws. On the E90 you need to push in a tab to release them, very likely breaking it (I did). ECS sells replacements that may be easier to use.
http://www.ecstuning.com/BMW-E90-M3-...rior/ES248447/
Rear Jack pad removed (the locking tab was facing towards the front of the car, maybe different with front pad). The center hole in the frame is where the t-hook goes. I used a small pry bar to remove the pad but a screwdriver might have been a better choice.
      05-06-2009, 01:55 PM   #8
ff1600
51
replacement pad
Tischer has them. Part number 5171 7 123 311
List $13.42, sell for $10.74
      05-06-2009, 02:05 PM   #9
m3larson
28
Thanks for the info!!! I really appreciate the help. Great Forum!
m3post
