Connecting an Apple i pod
07-29-2006, 04:37 PM | #1 |
16
Rep 196
I'm sure you guys know the anwser to this.
When I get my new car, i am keen to connect my nano ipod to the cars stereo through the aux connection hidden in the centre arm rest. Question: Where can i get a cable from to connect the 2 together ? Cheers |
07-29-2006, 04:51 PM | #2 | |
THE Viv
184
Rep 4,743
Drives: 330i SE
You can try using the forum's search facility- top right on any page- it works wonders! You can get that cable from Maplin, Dixons, Currys or any other electrical store. Just one thing though- what stereo system have you ordered for your car, Snake Pliskin? Just in case you didn't know, you should be able to play mp3/wma audio files in the car, depending on which system you have (info courtesy of a post by London320d- cheers): Non iDrive cars: Dash Slot - MP3/WMA CD Changer - MP3/WMA from March 05 iDrive Cars with Professional Nav: Dash Slot - MP3 Only (with appropriate Car s/w level Oct 05 or upgraded) CD Changer - MP3/WMA from March 05 iDrive Cars with Business Nav: Dash Slot - MP3 (not sure about WMA) (with appropriate Car s/w level Mar 05 or upgraded) CD Changer - MP3/WMA from March 05 All the best. Viv |
07-30-2006, 08:18 AM | #3 | |
275
Rep 9,218
The nano has a dock-connector at the base (where you plug it into your PC). So you need a dock connector cable to use the line out. Do NOT get the Belkin cable in the linked thread - it's rubbish - it has a crappy little pre-amp that will throw the sound quality completely - don't buy it. Instead get the 'monster cable low profile charger': http://www.expansys.com/product.asp?code=120584 You'll also need a straightforward 3.5mm male / male STEREO connection cable - I got mine from amazon. Now .. something I wanted to check - the monster cable charges your ipod as well as providing the line out jack. In the armrest - next to the aux input - is there a 12 volt power adapter? I think I can see one in the photo in theother thread but it would be good to have this confirmed by someone in the UK. |
07-30-2006, 09:01 AM | #5 | |
THE Viv
184
Rep 4,743
Drives: 330i SE
The ipod adapters work well, as long as you aren't too bothered about changing tracks whilst you drive. In that respect, using mp3/wma CDs or DVDs (if you have SatNav Business or Pro) is far easier. Depending on compression, you can fit 100-150 mp3 tracks onto a CD without any problem. If you have the 6CD changer, you've got potential access to a total of 7 discs worth of music. Throw in the DVD drive if you have in-car SatNav (can't use it at the same time as SatNavPro use, but you can on SatNavBusiness) & with a double-layer disc, you have another 8.5Gb to play with- over 2000 more music tracks. I've got an ipod shuffle 1Gb & nano 4Gb, but don't use either in the car, because I'm happier using the in-car system. I'd rather leave the ipods at home when I don't have to keep them in the car. All the best. Viv. BTW- for those with idrive, the BMW MOST ipod interface is probably due for UK release in September- more info about JSpira's US test here |
07-30-2006, 01:45 PM | #6 | |
275
Rep 9,218
I had the aux input retro'd to my 530d when I bought it along with a power socket - sited in the passenger footwell. I use the monster cable charger I mentioned above and have a non damaging bracket and mount that keeps the ipod nicely to hand when driving: (NB: photo was taken when I still had the belkin cable - don't buy it!) It's a 30 gig job and it's nearly full, so I'm pretty keen to use it in the e90. I'm hoping I can tuck it into the armrest (actually wondering if it'll fit upright in the cup holder slot thing) and just lift it out when I want to change tracks. Less accessible than my current set-up but neater and the ipod is not visible to thieves. Might get crowded in there though cause I'll have the snapfit cradle as well for my phone. I modded my e60's aux input to improve the sound (removed some in-line caps and resistors) if the sound quality is muddy I may have to pull out the e90's cable and try the same trick. |
07-30-2006, 03:07 PM | #7 | |
571
Rep 7,519
Drives: 2009 E90 335i MT
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
07-31-2006, 02:02 AM | #8 |
16
Rep 196
Plenty of advise there guys cheers !
I have the standard professional steroe but have spec'd the optional 6 disc boot mounted cd unit. I am sure they are all mp3 compatible so you are quite right in that there is huge potential for cd storage there, but i also have a lot of songs on my ipod already so its handy to have the option to play it in the car, especially as the aux connection is there already. |
03-01-2007, 01:09 PM | #9 |
Rep 5
I was quoted £444 for a docking station in the glove box of my e92. Full control of iPod with steering wheel and idrive.
Seems a little steep though especially with mp3 already available. |
