HELP: weird sound after installing the coilover?
05-02-2009, 04:42 AM | #1 |
41
Rep 432
hi guys, I have installled my FK coilover with in two weeks, and there are some kind of weird sound when ever I go over a small bump etc... and the sound only came from the front more likely to the driver side. anyone have this similar situation? the sound is not VERY loud...but sound like no shocks or something..
I don't even know how to explain it. Please chime in if any experts. THank you.
05-03-2009, 04:35 PM | #3 | |
208
Rep 9,339
05-04-2009, 12:57 AM | #4 |
41
Rep 432
the sound like something hit the fender or bottom of the car.. not rubbing the fender tho..
imagine when the car is in fully stopped and just use your hand knock on the inner fender.. and that's how it sounds like. THanks
06-22-2009, 01:42 AM | #5 |
95
Rep 930
i have same situation like you.
still making noise.....need help
06-22-2009, 08:07 AM | #6 |
only in it for the torque - awuleth'umshini wami
50
Rep 425
Drives: sapphire black 335i
info
Need more info.
How low is the car now after install? (mm) Wheel and tire sizes? Is it a "thumping" or "clank" sound? Sound on both front wheels? Or ONE of the front wheels? What happens when you turn wheels and when you accellerate hard off the mark?
06-22-2009, 09:22 AM | #7 |
158
Rep 6,805
Does it sound like something hitting a plastic bucket?
MY07 A22 E90 N52Nxi
06-22-2009, 11:28 AM | #8 |
95
Rep 930
kind of.
i heard sound from driver side not passenger side. it's not loud sound, and if you go to small bumps, it make sound... is it might be sounds from spacer spring on front coilover.? because i have fk silverline. and front have two spring each side.
06-22-2009, 11:41 AM | #9 |
103
Rep 1,760
Is the sound a clunking sound? If so, it may well be the front sway bar end links. This happened to me in my G35 coupe after installing lowering springs. I suddenly heard this clunking sound when going over small bumps at low speed (20-30 mph). When I brought it to a shop, we saw that the front left end link was bent and that was causing the clunking noise. I replaced it with an adjustable end link which resolved the issue.
2015 BMW X5 35i M-Sport (White/Brown) - 4/16/18 (Current)
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST | 1998 Acura Integra (Black/Black) - PAST |
