Uneven suspension level
04-30-2009, 12:56 AM | #1 |
85
Rep 1,523
Ever since day 1, my car has had different ride heights. I currently have the ZSP suspension with 15,xxx miles. The fronts are normal, but the rear seems to vary. What's for sure is that the rear left has always sat lower than the rear right side. Additionally, sometimes the drivers side is almost tucked (1 finger gap) while the right side has a 2.5 finger gap. Pretty significant. I have noticed this height difference on different surfaces while parked. I originally thought the right side would be lower than the left to accomodate the drivers weight when sitting in the car.
Does anyone have the same problem? There is one guy overseas who had a similar issue but could not find a resolution. Should I take this to BMW as I still have my factory warranty? Thanks, Jay
2002 Laguna Seca Blue E46 M3 6MT 2017 White C63 AMG Coupe 2002 Oxford Green E46 M3 6MT - Sold |
04-30-2009, 02:26 AM | #2 |
143
Rep 6,333
yes!!
2017 BMW M4 DCT Lease Transfer: https://f80.bimmerpost.com/forums/sh...8#post23736398
04-30-2009, 02:28 AM | #3 |
251
Rep 840
Drives: BMW F13 M6 // BMW F22 M235i
I have noticed an abnormality in my suspension. My rear left side is a bit lower than my rear right, By about 1/4 an inch or so. I can't tell unless it's on level ground. It's not noticeable from a distance or a quick glance. I only have 5,XXXmiles on it and believe my car's suspension may need time to settle down and loosen up.
BMW FTW!
"Power is nothing without Control" - Pirelli. |
04-30-2009, 02:30 AM | #4 |
Super User!!
24
Rep 579
thats weird cuz mine is the other way around my passenger side is lower than the drivers side..hmmm, i always thought since the battery is on that side maybe thats the case..
04-30-2009, 02:53 AM | #5 |
Watch This!
33
Rep 705
I know on the older E36 M3's this was caused due to the gas tank location. I'm not sure if it's the same problem on the E90's but it might be the culprit.....
04-30-2009, 09:50 AM | #6 |
85
Rep 1,523
hmm good to know. Has anyone brought their issues to the dealer? I hope to have some time to take it in and maybe they will replace the suspension. Or just throwing on some h&r sports on the stock shocks. What are your thoughts in this situation? Is it the springs problem or the shocks?
04-30-2009, 10:30 AM | #7 |
Smiling politely
165
Rep 7,931
Try measuring without a full tank of gas, then measuring with a full tank of gas.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
04-30-2009, 10:51 AM | #8 |
One cam is enough
130
Rep 6,801
I would suggest getting some coilovers if it bothers you that much....
When I had my E36 M3, the buzz was that the driver's side sat higher so as to sit level when the car had just a driver and no passengers (which was like 90% of the time). Not sure how much I believed it, so I got some coilovers and leveled it out. |
04-30-2009, 11:13 AM | #10 |
One cam is enough
130
Rep 6,801
04-30-2009, 11:41 AM | #11 |
85
Rep 1,523
This happens all the time; full fuel tank or not. And I don't see anyone else with this problem. I'll have to take it to the dealer and have them replace the suspension I guess. Unless they tell me it's a wear and tear situation and it's not covered!
04-30-2009, 12:38 PM | #13 |
62
Rep 1,211
The driver side should be higher. This is done as part of the alignment procedure to compensate for the driver's weight. If the passenger's side is higher with no one inside the car, then there is something goofy going on with the suspension.
04-30-2009, 02:17 PM | #14 |
441
Rep 18,331
I noticed that when i installed my coilovers, but realized that after many adjustments to the rear coilover adjustments the car seemed to still be lowered more on one side....after going crazy for a while, I realized the pavement in my garage was pitched and created this illusion that the car was not adjusted right....took it to a spot where its leveled and sure enough the car was even in the rear on both sides!!! To the OP...make sure when you look at the car its on a even roador surface
04-30-2009, 02:29 PM | #15 |
Moderator
618
Rep 10,855
There is something seriously wrong if you only have a one-finger gap on the driver's side rear and a 2.5 finger gap on the passenger rear. I would definitely have the dealer sort it out. Something is likely to have been damaged to have a difference > 1 inch.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
