M3 front Sway and ZSP sway?
04-28-2009, 01:19 PM | #1 |
675
Rep 4,080
Looking at the measurements provided
ZSP front sway: 26.5 mm 39310 mm^4 M3 front sway: 26.5 mm 39310mm^4 Are these sway bars essentially the same? What are the differences and would there be much noticeable difference between: ZSP Front sway / M3 Rear sway and M3 Front and rear sway? Thanks- |
04-28-2009, 01:29 PM | #2 |
56
Rep 617
See the attached pics: M3 sway has bushing stoppers so it does not slide within the bushings. Also it maintains a constant diameter all the way across. There is a slight dip in front on the stock front bar. M3 sway bushings are much stiffer and are not a block of rubber like stock. You can view my M3 Suspension Parts install here http://www.e90post.com/forums/showthread.php?t=230973
Stock front and rear sways Stock sway bushings M3 front and rear sways |
