How do I know if my wheels have tpms
04-20-2009, 04:22 PM | #2 |
Investor Relations
60
Rep 221
do you have nav?
If so, check the idrive info. menu.
'18 M3 ZCP | '13 RX 450h | '11 Range Rover Sport | '08 335i | '06 IS250 | '02 330 Dinan 3
04-20-2009, 04:25 PM | #3 |
72
Rep 1,217
Let some air out of your tires and see if the sytem throws a warning. Make surey you have a pump handy.
Or look at the valve stems. TPMS has different stems than the system that monitors wheel rotational velocity. |
04-20-2009, 04:32 PM | #4 |
37
Rep 1,165
Rubber stem = no TPMS
Metal Stem = TPMS My 07 335 is an early production so no sensor in the wheel, but it's monitored thru the ABS system.
2020 X3 X-Drive 30i; Alpine White/Mocha
04-20-2009, 04:39 PM | #5 |
HYEPWR
100
Rep 2,868
You most likely have TPMS...if you want, go to a pump and reflate a tire, if the system shows a low tire it will alert you, then pump tire back up!
2002 330ci Titanium Silver / Gray
2005 X5 3.0i Black Sapphire Metallic / Black 2002 M3 Laguna Seca Blue / Black 2001 M5 Jet Black / Black |
04-20-2009, 04:40 PM | #6 |
12
Rep 102
No NAVI. System will throw a warning when low. Valve stems are rubber.
Ok, just refreshed and saw bim's post. So if I buy wheels I obviously don't need to buy TPMS, will the low pressure warning still work with 19s? |
04-20-2009, 04:43 PM | #8 |
137
Rep 1,914
04-20-2009, 04:44 PM | #9 |
137
Rep 1,914
Yes, as long as you don't have TPMS. I also assume you have a sedan.
04-20-2009, 04:46 PM | #10 |
12
Rep 102
04-20-2009, 06:15 PM | #12 |
171
Rep 2,057
04-27-2009, 02:56 AM | #14 |
161
Rep 7,377
I have coupe 05/07 build with 19 inch wheels and aluminium stems but no TPMS sensor in the wheels. Does this mean its controlled through the ABS ? Based in Europe
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
