how low is too low
04-20-2009, 02:26 PM | #1 |
52
Rep 986
how low is too low
I understand the lowest one should go on the 335i suspension is 1" around.
what is the technical reason for this? Does it have to do with suspension travel? I know you need stiffer springs to support the lowered car? |
04-20-2009, 03:39 PM | #2 |
Where'd my VTEC go?
481
Rep 6,067
too low is when you scrape on flat roads.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
04-21-2009, 09:53 AM | #3 |
newborn bimmer patriot
47
Rep 280
It really depends where you live.
I live in Hong Kong, and I've been into an indoor parking that I would get scratched if I didn't go diagonally on ramp, AND I'M RUNNING ON STOCK SPORT SUSPENSION, which there are like 4 fingers wheel gap at the front.
2008 E92 335i
JB/SB/Alum | Sports | M3 Tri-Stiched Steering Wheel w/ paddles | Full M-tech bodykit | Vorsteiner Bootlid | 19" LC Z2S | and more's coming... |
04-21-2009, 10:00 AM | #4 | |
52
Rep 1,714
When you lower a car, the drastic change in roll center will make a car MORE likely to lean in corners, unless you compensate by stiffening the springs. Additionally, the geometry of the suspension goes to hell when you over-lower a car. I run a D/A Tc Kline kit with camber plates and I set it purely for track performance. I have it set to the highest possible ride height, to maintain optimum suspension geometry. |
