M3 Fuel pump failure ??
04-13-2009, 09:26 AM | #1 |
40
Rep 2,652
WTF !!!
Dash has just flashed up like a fecking christmas tree REDUCED POWER ENGINE FAULT and FUEL PUMP FAILURE Please drive MODERATELY and contact BMW Service which i will do in the morning,all in the middle of a play with an RS4 Deffo feels as if its missing or something ???? anyone heard of this ............. |
04-13-2009, 09:31 AM | #2 | |
Moderator
324
Rep 5,493
Yup - have seen this before unfortunately... however the cases I've seen haven't necessarily related to the fuel pump. One of them was that fuel pressure was down, and it was diagnosed to the injectors as opposed the pump itself. On another car, the fuel pump itself had effectively packed up of its own accord. And on a third, there was a huge amount of sludge and sediment in the fuel filter and pump itself, so caused a blockage and pump failure. That was because the twattish owner had run it virtually bone dry three or four times.... muppet... As the car says, a trip to the dealer is in order
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
04-13-2009, 02:03 PM | #3 |
272
Rep 3,658
Drives: E70 X5 xDrive35d M Sport
Garage List 2011 BMW S1000RR Sport [10.00]
2009 E92 M3 DCT [0.00] 2010 Range Rover Sport [0.00] 54 Plate E46 M3 CSL [0.00] |
Is running the fuel that low really an issue these days?? Surely there cant be that much, if any sludge/sediment in the bottom of a modern petrol tank and especially on a new-ish car???
E70 X5 xDrive35d M Sport - Carbon Black - Panoramic Roof - 21" BMW Alloys - BMW Performance Gloss Black Grilles - LCi Rear Light Upgrade - BMW 4.8i Exhaust Trims
04-13-2009, 02:08 PM | #4 | |
83
Rep 1,557
The pumps are usually cooled by the fuel, so running dry isn`t a good idea. Loosing fuel pressure at very high speed can cause cylinder(s) to run lean, overheat and eventually melt the piston crown, in a surprisingly short amount of time. |
04-13-2009, 03:48 PM | #5 |
Defected to the dark side.....
210
Rep 5,795
Drives: BMW M5 LCi
Bad news Calvin
I had the same issue on my 'vert when it was almost new, that needed a new pump also. Like Tone says tho, maybe it is not as serious as all that? Hope you get it sorted soon buddy |
04-13-2009, 06:44 PM | #6 |
148
Rep 1,060
As rede93cab says I also had a injector failure within 1000 miles new which resulted in warning lights and a misfire. I also had the high pressure fuel pump failure a few thousand miles later same symptoms with warning lights. When checked on dealers computer different fault codes were thrown up. In total had 3 sets of injectors due to recalls, precautions. I know I,am not talking M3 but could well be a faulty injector.
G15, 840i M Sport
04-14-2009, 03:06 AM | #7 |
337
Rep 8,811
Sorry to hear that Calvin, get your baby down to the stealers
04-14-2009, 03:34 AM | #8 |
272
Rep 3,658
Im assuming that running your car "low" on fuel ie, warning light on for a few miles etc is perfectly fine? Its the running it "dry" ie til car cuts out is the bit that does the damage, right??? I often drive til the light comes on but ive never driven a car til it completely cuts out.
04-14-2009, 03:36 AM | #9 |
Rep 171
Drives: BMW F31 330D MSport
You'll have to use your Magnetic Tow!
Be sure to hook up to an RS4
04-14-2009, 03:47 AM | #10 |
272
Rep 3,658
04-14-2009, 12:23 PM | #12 |
The Tarmac Terrorist
949
Rep 29,345
Drives: 997.2 GT3
quite likely on a F/I engine yeah.
997.2 GT3
04-16-2009, 12:44 PM | #13 |
172
Rep 7,953
Drives: Merc diesel
Garage List 2010 TTRS [9.00]
2007 Audi S5 [0.00] May 2007 Porsche 99 ... [0.00] March 2007 Porsche ... [0.00] Sep. 2007 E92 335d SE [0.00] July 2006 E90 330i ... [0.00] |
Any news yet?
