04-11-2009, 04:41 PM | #1 |
photographer
57
Rep 571
DIY: Headlight Level Adjustment
After installing my KW V2's I needed to realign my lights, and although I found information on how to do this on the e90's and e92's, there were no pics of the e82 lights and where to adjust them.
Location of the adjustment screw: Using a 6mm allen hex (the one in the tool kit works perfectly) turn the screw counterclockwise to raise the lights, and turn it clockwise to lower them. I recommend parking the car 20 or so feet from a wall and adjusting them that way, any closer and it's hard to tell how high the lights are actually hitting. I had to turn mine about 5 turns each, but unless you are as low as I am I doubt that's necessary for most people. |
04-11-2009, 05:19 PM | #2 |
aka 1013MM
1249
Rep 9,545
I was reading your DIY until PedoBear creeped up on me....
04-11-2009, 05:24 PM | #3 |
↓↓↓ Ex-Con ↓↓↓
34
Rep 1,874
True... true... so what is the story behind that sticker being under your hood amsfoto?
04-12-2009, 01:13 AM | #4 |
323
Rep 1,804
I thought they were auto-leveling.
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
04-12-2009, 03:00 AM | #5 |
SUPERMAN
121
Rep 3,171
wait is this the same on the e90 335?
cuz my headlights are too low that i have to ride with my highbeams all the time
MODS: JB3 18ohm | AR Design Catlles Downpipes | CDV Delete | Clutch Masters FX400 | ZEX Nitrous Kit | Devils Own Methonal Kit | VMR V701 (Matte Black) | H&r Race Springs| BMW Perf Grilles|
04-12-2009, 04:04 AM | #6 |
photographer
57
Rep 571
They are, but you need to be able to set the default height that the lights are at when the car is on level ground...the auto leveling is just +/- degrees from the default based on suspension travel.
The e90's adjustment screws are in a different place on the top of the housing. It's a black adjustment screw...search on e90post and there are some write ups with pics of where the screw is. |
04-12-2009, 04:02 PM | #7 |
323
Rep 1,804
Oh, ok. Yeah, I remember seeing the headlight leveler on the passenger side suspension when I saw installing my sways.
-Nick
04-14-2009, 06:41 PM | #9 |
gone but not forgotten
35
Rep 985
I was having this issue and I knew the screw was somewhere. I gave up looking and gave it my dealer during a service call. They made them a bit to high tho. So its good to know where they are.
Thanks for the DIY!
Our Lady of Blessed Acceleration don't fail me now.
06-03-2009, 09:29 PM | #10 |
121
Rep 2,036
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Thanks for the info. I noticed the same problem for the first time last night, I guess it was the first time I had drove after dark since installing KW V1's a couple of weeks ago. I only lowered around 20mm but for sure the lights were aiming substantially lower than before. I figured with such an automated car that adjustment might be complex.
06-14-2009, 10:16 PM | #11 |
121
Rep 2,036
I adjusted my headlights a few days ago and I seem to have gotten them about right. I just guesstimated. I parked about 30 ft from a block wall and raised each light about one block height higher. I'm still amazed that lowering only 20 mm threw off the lights this much. I guess I turned around 4-5 full turns also. About the only funny thing was that it might have just been the angle of approach, but I had to use different devices on each adjuster, almost like they were different sizes.
06-28-2009, 12:36 PM | #12 |
81
Rep 1,075
Yea, I just used that size allen to turn mine four turns ccw (to raise them). I'll see how it looks later tonight.
Ordered 4/7/08, Delivered 5/15/08, Sold, but not forgotten.
09-18-2009, 10:47 PM | #13 |
177
Rep 6,631
Awesome! It was downright embarrassing to have one headlight blazing into a fellow driver's eyes, and I have no idea how it happened. At first I thought the DIY meant that that adjustment screw adjusted both headlights, but I said F it and went to my car and checked to see if they were headlight specific, and it was! My headlights are now perfectly aligned and I won't lose sleep at night thinking about all the people I was blinding with one of my headlights blinding the driver in front of me!
E90 LCI N54 6AT
10-27-2009, 04:53 PM | #14 |
29
Rep 488
Just raised mine one full turn. I'll check tonight how much difference it makes. I made a little tick mark with Sharpie on the screw and the surrounding area just for reference. Makes it so much easier to adjust, no guessing.
10-27-2009, 05:00 PM | #15 |
19
Rep 196
^ +1
Scream till you like it.
06-07-2010, 12:35 AM | #16 |
210
Rep 959
I installed BMW Performance suspension do you think I have to adjust my headlights?
06-07-2010, 09:43 AM | #17 | |
Lord Captain Commander
110
Rep 3,093
Now they actually illuminate the road properly and don't dazzle oncoming drivers.
E82 135i M-sport: SGM/6MT/Black |
09-07-2010, 06:41 PM | #18 |
44
Rep 567
Thanks for this. Great info! I found the adjusters and raised my lights quite a bit. Now need to go for a drive and see how Huey are working, they were pointing much too far down from the factory. I think it is a DOT thing... In order to meet DOT requirements, the lights end up being dipped. Here in Nortthern VA, the state inspection guys don't even bother to check headlight alignment anymore because they assume xenons do that by themselves.
Can't wait to see the difference! FYI, yes, setting the light switch to auto turns on adaptive headlights. It is a cool feature, more useful than I had expected. |
05-15-2012, 04:12 PM | #19 |
Rep 31
Does anybody have an updated photo of where the adjustment is? The OP's picture isn't showing up anymore.
05-15-2012, 10:23 PM | #20 | |
374
Rep 2,388
Drives: M2 Competition
Both look like this, each one is tucked a little behind your headlight Good luck Last edited by Venom; 05-15-2012 at 10:31 PM.. |
05-15-2012, 10:33 PM | #21 |
398
Rep 9,156
I'll try and snap one if I remember. It's a white little circle. Make sure you count the rotations. I did this myself and was driving around for weeks with one light pointing up and one down without knowing.. failing hard.
05-15-2012, 11:20 PM | #22 |
374
Rep 2,388
I love this mod, too many people drive slow in the fast lane, so its my way of saying GTFO my lane! hahaha (one can always dream of driving on the Autobahn, where the left is a passing lane)
