04-07-2009, 03:22 AM | #1 |
76
Rep 676
Magnetic numbers for track days/autocross?
Does anyone know if magnetic track numbers will work on the sides of a 135i? I'm not sure what the doors (or rear side panels) are actually made of. Has anyone had any experience with this?
135i // M-Sports Package // RR Oil Catch Can // Black Kidneys // iCarbon Hood // Alum Pedals // KW v2 Coilovers // Vorshlag Camber Plates // Hotchkis Sway Bar // Wheel Studs. Best mod ever? Tires. 255's in front, 275's in back.
04-07-2009, 04:20 AM | #2 |
16
Rep 355
If you have 'permanent numbers', go to a sign shop and have them made. You can have the numbers made the way you want them. Also you should have them made on a flat sheet which could be chosen to match the color of your car or contrast with it. Don't get just the number there is too much frontal area compared to the gripping area and the numbers won't stay on your car at any kind of speed. On the track for added security tape the leading edge of the number panel with a small amount of racers tape. So it's a good idea to get your number panel in the same color as a big roll of racer's tape.
Alan
08 135I (AW/Coral Red - delivered 3/15/08 -- 13 Audi S4, 83 SC (trackster), 90 C2 (Sally's Carrera), 04 Avalanche Blingmobile |
04-07-2009, 09:54 AM | #3 |
76
Rep 676
Ah, good tip on the tape. By "permanent numbers" though, do you mean that the numbers themselves never change? Or did you mean permanent as in "they aren't removable"?
I'm trying to figure out if magnetic numbers will even "stick" to the doors of a 135. I'm thinking of just ordering a magnetic oval from here.
04-07-2009, 10:10 AM | #4 |
141
Rep 1,401
04-07-2009, 11:11 AM | #5 |
16
Rep 355
I meant permanent as you are assigned a number for the season e.g. 46 - If you show up for an out-of-region event where someone has stolen your number, you may change it with painters tape - leading 1 or trailing 1 as in 146 or 461
Alan
04-07-2009, 08:27 PM | #6 |
76
Rep 676
Great advice everyone.
Any suggestions on size? I think I'm just going to order some magnetic numbers from here. What size should I get? Also, I notice that I can order a few letters for "class" denotations. The suggested letters are "CSP". (see here) Any suggestions there? (I'm trying to order these before the car actually gets here, and then attend a track day not long after. )
04-07-2009, 09:52 PM | #7 |
141
Rep 1,401
^ $110-169 seems VERY steep for simple magnetic numbers. Especially if it's just a set of standalone 0-9 + class letters (most of wihch you won't use). For that price you should be able to find something much nicer.
If you want simple stand-alone numbers like that you're much better off buying some of the material and cutting them out yourself. It's a hell of a lot cheaper and you have full control over the result. You'll also have some extra material if you ever loose a number or change your class. All you need are a pair of 2 (at most 3) numbers and class letters. I personally just have a 1, 5, 6 and DS for each side which provides more than enough possible combinations. As a bonus, mine were free since a coworker had extra magnetic material laying around. If you want something fancier, someone else may be able to point you to a better source. |
04-08-2009, 12:39 AM | #8 | |
20
Rep 343
http://www.vistaprint.com/vp/busines...agnet&ad=broad IIRC, a set of 2 costs approx. $30 shipped! White background is best for ease of visibility and photos. |
04-08-2009, 01:22 AM | #9 |
76
Rep 676
ooh that's not a bad idea. Is the magnet thin enough to cut the numbers out?
04-08-2009, 09:48 AM | #10 | |
16
Rep 355
To make number plates yourself get the larger door magnet which provides less frontal area then almost any number. Use the door magnet and vinyl coat it or paint it and attach vinyl numbers to it. If you have a white car or you have a different color car, attach the vinyl numbers directly to the magnetic panel without painting it to match your car before hand. You can even lay one color vinyl number over another to achieve a shadowed look.
Alan
04-08-2009, 01:40 PM | #11 | |
Rep 222
i tried with some success some reusable vinyl numbers. they stick well at first, but eventually you get grit/dust on the sticky side, and eventually you have to replace them. lately, i have been using temporary spray paint that you can get at autozone. you can have flexibility as to the number and size. you have to cut out a stencil, which takes all of 3 minutes, and spray. this is also pretty ghetto, but tidy enough, and cleans up easily. http://www.duplicolor.com/products/carart.html |
04-08-2009, 04:49 PM | #12 |
16
Rep 355
Everyone has an opinion. The tape does not have to be done in a way that appears to be ghetto. Particularly if your number panel is the same color as your racer's tape. Perhaps I will take some pictures this weekend at Summit Point to use as examples.
Alan
04-12-2009, 11:21 AM | #13 |
LEFT LANE FOR PASSING ONLY
Rep 38
I'll get a better photo of mine up soon, but this works perfectly. I drew up a word document and emailed it to a local franchise type of print shop (Fast Signs I think) and they had it done in 4 days for $60 (2 magnets). I made this one similar to what the BMW Motorsports uses for their race cars. BMW Motorsports at the top, number in the middle, & BMW 128i Coupe on the bottom. Black line arount the edge. They rounded the corners so it would not peel away. If you are doing SCCA & need to indicate class have it printed or just add some blank spce to the right of your number and use the vinyl stickers. The next one I do will have some colors and some blank space to the left of the number for sponsor type stickers & possibly my last name.
04-13-2009, 09:14 AM | #14 |
HALA MADRID!
938
Rep 2,877
F87 M2 Competition, Sunset Orange, Exc, DCT. **SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015 **SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. |
04-13-2009, 11:21 AM | #15 | |
76
Rep 676
^ Thanks for the link!
04-14-2009, 09:58 PM | #16 |
12
Rep 118
Good options here as well, happy with mine:
http://www.soloperformance.com/
2008 135i Sparkling Graphite Metallic - 6Sp - Black Boston Leather - Gray Poplar trim - Sport Package
Premium Package - Comfort Access - iPod/USB - HD FM - Premium Hi-Fi - Heated Seats 5/27 Euro Delivery Welt - 6/5 Drop off AMS - Re-Delivery 8/8 - SOLD 8/2015 |
04-16-2009, 11:18 AM | #17 |
20
Rep 338
Drives: 2006 BMW M5 / 1974 BMW 2002
I'm having mine made. My bro-n-law did this one for me. Lmk which one looks good. Thx. Sorry for being so big..as ineed it to uplaod to a website.
2006 BMW M5 7spd SMG/SIlverstone : 2008 BMW 135i SGM/JB2/BMS(SOLD 1/2010) : 1974 BMW 2oo2(5spd w/ 3.91LSD) : 2002 BMW M3(AW/6spd) Sold 8/07 : 2002 BMW 325i(SGM) Sold 12/07 : 1993 BMW 325i Sold 8/04 |
04-25-2009, 02:05 PM | #18 |
76
Rep 676
Which size do you think would work well with a 3-number (no class letters) oval shape? My 135i is still on the boat or I'd just go out an measure.
Click here for the size chart (it's huge or else I'd just put it in this post) Initially I'm thinking 20" wide and 11" tall is pretty darn big on a 1 series.
04-25-2009, 03:00 PM | #19 |
12
Rep 118
10" numbers with 5" letters on my 135i
04-26-2009, 04:18 AM | #20 |
76
Rep 676
Thanks BimmerMeUp! That was very helpful. Did you choose removable vinyl, magnetic, of permanent vinyl for those numbers? They look great.
04-26-2009, 11:17 AM | #21 |
12
Rep 118
Those are magnetic. That's pretty much what everyone uses at our autox events. Vinyl can look great, but is more of a pain to put on (have to work the bubbles out with some solution) and don't last as well (get dirty). The magnetic material from Solotime works great, we only occasionally have to retrieve someones numbers from the course, and usually that's because they have gotten curly and have edges sticking out into the wind.
I store mine on a box I built with a top made from an old whiteboard; the older whiteboards were made from sheet metal and magnets stick. I've seen folks with a loose leaf binder of sheets of metal to store numbers - you want to try to keep them clean and flat. Sometimes, if it is cold, I'll let them sit on top of the engine for a few minutes to warm up, then they bend to body contours better than if cold and stiff. Good luck!
04-26-2009, 12:05 PM | #22 |
141
Rep 1,401
