Putting on Tires with Higher Sidewall? -> 18" Style 197
04-06-2009, 08:40 PM | #1 |
is also an E46 Fanatic
39
Rep 538
I just got a MASSIVE bubble and I will be replacing my stock RFT's with Michelin Pilot Sport A/S Plus tires from Tirerack.
The recommended sizes are: 225/40-18 --F 255/35-18 --R Can I get away with a higher sidewall? I was thinking about: 225/45-18 --F 255/40-18 --R The reason I want a higher sidewall is that it might not bubble as easy and I hoping to get rid of some wheel gap in the front, the back is okay. What do you guys think? |
04-06-2009, 09:35 PM | #2 |
Professional Moose Racer
316
Rep 7,509
Are you lowered at all?
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1 |HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM |
04-06-2009, 10:12 PM | #4 |
BimmerPost Supporting Vendor
2042
Rep 25,989
Your less likely to rub since your are at stock height but it is still possible during compression or full cabin of passengers. Since you are jumping from a 40 to a 45 series, you will be increasing the side wall my 1/2 in and the overall diameter by 1in causing the speedometer and odometer to go off. I would recommend staying within the recommended sizes.
Feel free to PM me if you have any further questions. -Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
04-06-2009, 10:33 PM | #5 |
39
Rep 538
Charles,
Do you think having a bigger sidewall on the front tire will make it look odd? Currently with a full load of passengers the car rubs over bumps in the rear, the front has a massive wheel gap, so i don't see that being a problem. Will having that extra inch make it front look goofy if I stick with OE suggested in the rear? Thanks so much |
04-06-2009, 11:24 PM | #6 |
93
Rep 685
I'm not so sure if having a taller sidewall will reduce bubbles, and if that is your main reason, I would stick with the OEM sizes. Just avoid those potholes
Also, if you get a taller sidewall, your car is going to be higher off the ground. I wouldn't raise the car to fill fendergap. If anything I would lower the car |
04-07-2009, 05:09 AM | #7 |
48
Rep 1,162
Drives: E90 328i 6MT
I doubt that you'd want to do this...
If you want a bigger sidewall, you could go with 17" 225/45 and 255/40, which is what the E90 328 ZSP comes with. The net effect of doing this would be using 1" smaller wheels with the difference being made up with 1/2" taller sidewalls in the tires. |
04-07-2009, 04:42 PM | #9 |
2042
Rep 25,989
06-15-2009, 07:16 AM | #10 |
No military grade
58
Rep 619
Sorry, but I did not see this post earlier. That setup works like a charm, I have it.
Look at my pictures here. Tire brand is Bridgestone RE050A Non-RFT, speedindex Y. The car is a 335i with M-sport suspension, which is standard on the 335i in Germany, about 1 inch lower than normal. The E92 has less space in the wheel wells than E90/E91. So if you are not gonna lower it more than that, it should fit just fine. Side effects of the larger resulting diameters: - more exact speedometer reading - softer ride - better filled wheel gaps - higher max speed |
