URGENT Need Tire Size Help.
04-06-2009, 09:46 AM | #1 |
238
Rep 17,761
Hey I've got a set of Privat gassens 19x8 et40 fronts and 19x9.5 et25. Ive found a awesome deal on on some generals but i just need to make sure that i can run this set up and if I'll run into any problems with this. So will i be fine running:
235/35/19 on the front 19x8 et40 and 265/30/19 On the rear 19x9.5 et25 thanks in advance |
04-06-2009, 10:07 AM | #2 | |
El Presidente
278
Rep 6,962
04-06-2009, 10:01 PM | #6 |
BimmerPost Supporting Vendor
2040
Rep 25,989
19x9.5 +25 on a 265 might work since you are at stock height. If you ever decide to lower, you'll most definitely need to roll the fenders. We've had a few guys running aggressive M3 9.5" +22 on 265's with rubbing issues.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
04-29-2009, 03:48 PM | #7 |
238
Rep 17,761
Sorry but i gotta bump this again. Will this work?
Tires are gonna be generals 245/35/19 On the front 19x8 et30 and 275/30/19 On the rear 19x9.5 et25 |
04-29-2009, 08:21 PM | #8 |
2040
Rep 25,989
Front fitment should be fine, but may need a very gently fender roll depending on ride height. As far as the rear, that is definitely going to need to be rolled and possibly pulled slightly.
-Charles@VMRWheels www.vmrwheels.com
04-29-2009, 09:39 PM | #9 |
Super User!!
24
Rep 579
front is fine... rear needs to be rolled.. im running 275/9.5 +25 but on falken which has round sidewall compare to generals.. I can probably clear another 3mm.. but then again different tires different story.. hope this helps...
04-30-2009, 11:07 AM | #11 |
1569
Rep 29,202
I'd go with 235/35 and 265/30. No need for 245 on the 8" wide front wheel or 275 on an ET25 rear wheel.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
