Wheel spacer removal
04-02-2009, 01:34 PM | #1 |
40
Rep 660
Im taking off, or trying to take off my h and r 15mm spacers,, and they wont budge.
What is the trick here guys. I install them, just as is, no glue. thanks. Also these will be up for sale soon... special deal for the best helper!!! thanks |
04-02-2009, 01:45 PM | #2 |
28
Rep 230
*subscribed*
I had the same issue a few months ago when trying to put my winter setup on. I ended up quitting and just using the spacers all winter. Eventually though, when I return the car, I will want them back. I didn't put too much effort into it mostly because I was afraid of damaging them. Aluminum is easy as hell to dent!
Jet Black, 6MT, CW Pkg, PS, iPod, Style 189 Wheels |
04-02-2009, 02:17 PM | #4 |
Rep 280
Just whack at them with a rubber mallet. The force you exert is much less than the force of bumps in the road.
Basically it has either corroded and fused together with rust or, depending on the material of the hub and spacer, they can fuse together ( i forget what this process is called) |
04-02-2009, 02:31 PM | #5 |
25
Rep 395
+1 mallet will work
use never seize, thats what I do whenever I work on anything in the engine room on my ship.(main engine bolts are tightened to-600 bar and it still works) Sometimes we use heat/ice to get frozen bearings out or 6 ft. sledge hammers when nothing else works......
SOLD......E90 SG, ColdWeather Pckg, Sport Pckg, Logic7,H R Sports, Rogue Ikon, M sport shift knob/boot
04-02-2009, 02:53 PM | #6 |
173
Rep 6,223
what i did is i spray some WD40 between the brake and the spacer, and put a flat head screw driver between them...slowly move the screw driver, then it pops out!
2006 E90 Alpine White 330i - Retired
2015 F80 Alpine White M3 |
04-02-2009, 03:04 PM | #7 |
28
Rep 230
Are you kidding? I feel like this is guaranteed to put a dent in the spacer and in turn, screw up your alignment.
04-02-2009, 03:05 PM | #8 |
173
Rep 6,223
i m not kidding, of course that i didn't put force on it man...and i never said i turn the screw driver to make the spacer off!!well..if you don't like the way i did, then forget my idea!
04-02-2009, 03:11 PM | #9 |
28
Rep 230
Ha...no hostility intended! I'm just terrified to try this myself!
04-02-2009, 04:19 PM | #10 |
173
Rep 6,223
i just used the screwdrive to hole the spacer, then i can use my hand to take the spacer off, but spray some lubricate liquid will work for sure!!
04-02-2009, 04:30 PM | #11 |
///M Specialist South Shore BMW
772
Rep 7,108
use two metal spacklers to slide under the spacer. I use two because it is less likely to bend the spacer.Keep doing it on opposite ends and it will come off. Next time buy rogue engineering spacers because they are notched so you can get something underneath it to take them off.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
04-02-2009, 04:56 PM | #12 |
85
Rep 1,523
Mine comes off so easily. Someone needs to hit the gym.
2002 Laguna Seca Blue E46 M3 6MT 2017 White C63 AMG Coupe 2002 Oxford Green E46 M3 6MT - Sold |
04-03-2009, 03:42 PM | #14 |
Master of my own domain!!
153
Rep 1,049
Please, I had to literally beat mine off a claw hammer and a sledge. They fused to the rotors and were not coming off. Had to use the claw part of the hammer and a small sledge to hammer it in between to pry it off. Horrible. Ruined the spacer needless to say although they were messed up anyway.
04-06-2009, 04:36 PM | #16 |
40
Rep 660
Guys,, these are soooooooo froozen on,,, I mared one with a screw driver,,, then got out a dry wall knife,, didnt go in.
I then thought ,, if I do get it to budge,,, and not off all the way, its going to F up my holes for the bolts,, then Im really fubar........ i just left them on,,,,,,,,,,had it up to service and the grease monkey didnt say shiet about them.. Soooooooo,, they are staying on,,, next time,,, anti seeze...... thanks for you imputs boys and gurls........... O ya,,,,,,,, I do workout,,,,,,, I do gurl pushups till the cows come home.!!!!!!!!!!! |
04-06-2009, 04:40 PM | #17 |
335
Rep 7,719
Mine comes off easily as well, but I have seen a member who had to chiseled his spacers off because they were stuck on. I'm not sure what is the culprit, but his was glued on...took nearly 30 mins to get both sides off.
