Bled clutch, and now clutch pedal to floor--help
03-29-2009, 08:48 AM | #1 |
19
Rep 125
I bled my clutch with a motive pressure bleeder. I kept the master cylinder full at all times, but I keep getting air out the bleeder valve, and the clutch pedal is dead. How do I fix this? Thanks.
03-29-2009, 10:08 AM | #2 |
Bootleggin' 'n Gunrunnin'
137
Rep 2,372
I think the fluid reservoir is divided with baffles, so maybe the clutch side drained out while still looking "full" on the other side of the baffles?
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
03-29-2009, 10:21 AM | #3 |
Gobble gobbledygook
Rep 287
+1. The reservoir feeding the clutch is rear-facing, and appears to be much less in volume than the front-facing, brake-serving reservoir. I had to persuade the mechanic bleeding my clutch to just add brake fluid and try again.
03-29-2009, 10:22 AM | #4 | |
Modder Raider
753
Rep 8,633
Drives: M3
Every time I bled the clutch, I did it the old fashioned way with my neighbor. Once I tightened the valve, the clutch stayed on the floor, so we had to pull it up every time. Hope this helps.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
03-29-2009, 10:58 AM | #5 |
19
Rep 125
I thought I had it, and put everything back together. Then I start it up, and the clutch is still on the floor, and I couldn't even put the car in gear. Guess, I have to start all over again. The clutch pedal should be in the up position when bleeding correct? Thanks in advance!
03-29-2009, 01:30 PM | #6 |
19
Rep 125
Okay, got it fixed. I made sure the pedal was pulled all the way up before bleeding again. I bled the clutch, and checked the clutch pedal feel before putting things back together. It feels solid now. Just have to make sure the clutch pedal is all the way up before going under to bleed the clutch valve. Thanks for your inputs.
