What do you guys think about this setup??
03-23-2009, 08:03 PM | #1 |
229
Rep 3,550
Hey guys,
what do you think about this setup? Is it comparable to a KW coilover system? Is it worth the money or would just replacement springs do just as good? http://www.**********s.com/product.a...springs_E9x_JS
Current:
'13 F10 535i xDrive - lightly modded for now Previous: '12 e92 M3 Melbourne Red/Bamboo - ADV.1 ADV10, Volk TE37SL, OSS, Innotech F1, Arkym, iND '09 e92 335i Alpine White/Saddle Brown - fully modded |
03-23-2009, 10:13 PM | #2 |
375
Rep 17,017
The difference between the two is that the KWs are an adjustable coilover so you can dial in the ride height (and stiffness if you go with KW V2s). The FSD system has a built in dual valving system that automatically stiffens under cornering but rides smooth under normal conditions. The FSD kit is not height adjustable so you are set with the spring height. If this is not something important to you, I see no reason to spend the extra premium on coils.
03-23-2009, 10:20 PM | #3 |
229
Rep 3,550
thanks for the help! so this kit won't completely slam my car though? I'm just looking for some moderate lowering, nothing crazy and just some better ride quality..
Current:
03-23-2009, 10:21 PM | #4 | |
Once upon a time ......
276
Rep 5,048
Drives: 2008 JB E92 - SOLD 5/2010
+1 I currently have the Koni FSD/Eibach combo installed and have enjoyed everything the system offers since last Summer. You retain the 'sporty" ride, get a mild drop all around and can hang in the moderate curves with the best of 'em. My sig (and garage pics) show the ride height while on 19" wheels. |
03-23-2009, 10:29 PM | #5 |
229
Rep 3,550
thanks so much! thats exactly what i was looking for.. i'm happy i don't have to spend a fortune for this stuff..
Current:
03-23-2009, 10:31 PM | #6 | |
276
Rep 5,048
Right on man ........... you'll truly enjoy the setup! |
03-24-2009, 01:21 AM | #7 |
nemo
Rep 130
03-24-2009, 02:10 AM | #8 |
Rep 48
I had same thought as you.
I installed Eibach spring over sport shock on my 328i. It drop the front about an inch and less an inch on the rear. The ride is very close to stock ZSP because the spring rate is very close to stock. I did feel about 10% less hesitatation on get going. I thought about getting FSD to get rid of the bouncing feeling. But I decide to get the KW V2 last minutes for 1. adjust high. Eibach just don't lower enough for my taste. 2. I am afraid the moderate FSD shocking effect does not make enough damping for my taste as well. I just installed the KW V2 and drove it for couple of hundred miles on mountain and freeway. I would say FSD/Eibach sit in between ZSP and KW V2. I may get FSD in the near future just for comparison. Oh I did have hotchiks sway bars for both setup. If you looking for flat turn sway bar upgrade is a must. |
03-24-2009, 07:32 AM | #9 |
276
Rep 5,048
The FSD/Eibach addition dropped the car another inch (or just a bit more). Perfect for 19" and having 2 passengers in the back ..... no rubbing whatsoever.
03-24-2009, 07:36 AM | #10 | |
276
Rep 5,048
03-24-2009, 07:37 AM | #11 |
158
Rep 2,561
850 is a fortune to me
I would totally do this if my dad didn't care lol.
Montego Blue 2007 E92 335i - ZSP / ZPP / Steptronic / Logic7 Broadway Static - CCW - Megan - Orion Instagram: bmwforlife |
03-24-2009, 07:40 AM | #12 |
276
Rep 5,048
If your dad was riding around in the car with you he would say "thank you" for this upgrade. Truly a difference of night and day .... as long as you're not on rflts!
03-24-2009, 02:46 PM | #13 | |
Rep 48
they claim the spring is lighter but actually 1 lb heavier than stock. |
03-24-2009, 02:58 PM | #14 |
276
Rep 5,048
LOL ...... I noticed that as well. Between changing the tires/wheels and rotors out I've lost around 40-45 lbs. already ... I can handle the extra 4 lbs.
03-24-2009, 03:48 PM | #16 | |
276
Rep 5,048
Mountain twisties ........ before switching to this setup I REALLY had to slow down for the 15-25 mph curves as the bodyroll was very pronounced. I never really felt that I trusted the car going into the turns. Since switching to the combo I have all kinds of confidence (sometimes too much for my own good) hitting the curves with limited braking. There is still some bodyroll (I haven't upgraded the f/r sways yet) but it is much more limited now. The car truly feels like it's holding onto the road more aggressively. City driving ........ I switched to this setup AFTER changing my wheels and tires to aftermarket. That said, the bumps are still very noticable but not to the point that you feel like you have to stop and check the tire/wheel for damage. The car is much more planted and DOES NOT squat when hitting WOT from a standstill. Even with 4 people in the car I have never bottomed out. I always expect to but haven't yet. Oh yeah, she hooks like a mofo. Roadtrips ......... made ONE roadtrip with the car stock. That was the only one. I couldn't deal with the back breaking discomfort after that trip. Again, suspension change came after tire/wheel change. The car is VERY comfortable now and pure joy going down the road. The closest comparison I could give in referencing another car would be that of a friend's Corvette ZR-1. Stiff, but not overdone. Not sure what else to say.......... if you go with one of the more aggressive setups so widely used here then chances are you're going to grow tired of the rough ride .. cool or not it has to be practical for me. In case you missed it earlier in the thread; the combo does lower the car about an inch or so from stock sport suspension. Hope this helps in your decision ..... |
03-24-2009, 08:27 PM | #18 |
276
Rep 5,048
03-25-2009, 05:09 PM | #19 |
361
Rep 5,859
Drives: Vorsteiner E60 M5
Location: 1460 White Oaks Rd. Suite F. Campbell, CA 95008
