BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
      03-20-2009, 05:52 PM   #1
SOARISTO
SOARISTO's Avatar
Japan
29
Drives: New M3 Coupe M-DCT
Cool [DIY E92 M3] High-Power White Angel-Eye Lamp
Hello, M3 Fighter Pilots!!
I made "High-Power LED White Angel-Eye" for my E92 M3 Coupe. So, I introduce it to you.
This is a comparison between a genuine H8 halogen lamp and my work.
This is the inside of genuine head-lamp unit.
The "Inner Angel Ring" has a reflector, but the "Outer Angel Ring" has not. It has the "Optical Glass Pipe" which leads the ray from the light source.
So, it becomes important that where is the position of the light source.
This is "Luxeon K2 with TFFC Cool White" (LXK2-PWC4-0180) which I used.
It has 250 Lumen at max current 1,500mA (3.85V).
This is a genuine H8 halogen lamp made by OSRAM.
Take it apart to the bulb and the base by milling machine.
This is the base.
It has two small pins in the inside. These are + and - from the H8 wiring.
The aluminum bar (diameter 15mm) just fits to the base.
Mill and plane the aluminum bar by milling machine.
This milling machine has the precision of 0.02mm pitch.
These are after milling and planing.
Combine the materials.
It has same distance between the filament and the base.
(In this image, it looks different because of its putting angle, but it has just same distance(34mm).)
It is only coupler-on to the H8 wiring, not needs cutting or other processing.
This is a case when the light source is not adjusted to the "Optical Glass Pipe".
It is often seen at several maker's products.
This is my work adjusted to the "Optical Glass Pipe".
More details, please see here.
(Sorry, it is written in Japanese. Use Altavista or others.)
Does anyone fight (compare) about the brightness of the Angel-Eye?
[Reference]
This is "High-Power LED White Angel-Eye" for E60/E61 that I had made 4 years ago.
One of the maker produced a product after a half year that I had made.
This is a comparison with one of the maker's product.
Which one do you look brighter?
This clearly shows the difference between two models.
(Characteristic of the polar radiation pattern)
Refer here and here.
(Sorry, these are written in Japanese. Use Altavista or others.)
      03-20-2009, 05:58 PM   #2
badfish
badfish's Avatar
100
Drives: E92 AW M3
2008 M3  [0.00]
Sweet Luxeon goodness. Can't wait to see the whole writeup...
      03-20-2009, 06:28 PM   #3
McLuVan
McLuVan's Avatar
Vietnam
304
Drives: ///M3
that's way to pro for a DIY
      03-20-2009, 07:49 PM   #4
Big Windy
Big Windy's Avatar
152
Drives: None
Originally Posted by McLuVan View Post
that's way too pro for a DIY
and +1!
      03-20-2009, 08:15 PM   #5
kmarei
kmarei's Avatar
Egypt
686
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
so when can we buy these?
      03-20-2009, 08:16 PM   #6
aajami
aajami's Avatar
432
Drives: Space Gray '09 E92 M3
Hey, Soaristo. You're alive. I don't mean to hijack your thread, but this one demands your attention:
http://www.m3post.com/forums/showthread.php?t=226909
Drop by and give us a hand
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem
      03-20-2009, 08:19 PM   #7
kmarei
kmarei's Avatar
Egypt
686
would these work?
http://cgi.ebay.com/ebaymotors/White...Q5fAccessories
      03-20-2009, 08:28 PM   #8
chinoxs203
chinoxs203's Avatar
122
Drives: 08 E92 335xi AW
Originally Posted by kmarei View Post
no their crap and throw a code because they dont have enough power. i tried a similar version
FOR SALE:
Dropbox - please
      03-20-2009, 09:54 PM   #9
SOARISTO
SOARISTO's Avatar
Japan
29
Smile Too much of one thing is not good.
Hello, kmarei.
It is not good thing that it has a lot of LEDs in case of the Angel-Eye.
The important thing is that where is the position of the light source and how to lead the ray to the "Outer Angel Ring" through the "Optical Glass Pipe".
That product has a lot of SMD LEDs, but it seems that it has not enough amount of light.
      03-20-2009, 10:04 PM   #10
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Originally Posted by SOARISTO View Post
Hello, kmarei.
It is not good thing that it has a lot of LEDs.
The important thing is where is the position of the source of light and how to lead the ray from the source of light to the "Outer Angel Ring" through the "Optical Glass Pipe".
That product has a lot of LEDs, but it seems that it has not enough brightness.
LED light travel much straighter than an incandescent light source, so like SOARISTO said, you really need to position the LEDs well to match up with the light tubes so that the rings will light up properly. I wonder how bright are these under direct sunlight.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      03-21-2009, 01:44 AM   #11
SOARISTO
SOARISTO's Avatar
Japan
29
Smile
Hello, Kev.
This is under the sunlight in the shade. It has almost the same brightness as the genuine halogen lamp.
(Under the direct sunlight, even though the genuine halogen lamp looks dark.)
      03-21-2009, 02:39 AM   #12
Islika153
Drives: 2009 BMW M3 coupe Space Grey
Way to much going on for me to dare try something like that.. can we just order your work. ;p
      03-21-2009, 06:01 AM   #13
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Hello, Kev.
Wow, sweet, that's really good.
      03-21-2009, 08:00 AM   #14
kmarei
kmarei's Avatar
Egypt
686
i wonder if we can make a setup with 4 bulbs with say 3 inch wires
so you can pace a bulb at the tip of each ring
so the outer ring would be lit up as well as the inner ring
      03-21-2009, 08:06 AM   #15
mds82
mds82's Avatar
364
Drives: 2006 325xi
The only problem with this is.... when you turn the headlights on then the voltage drops and it is too low for the power regulator to handle, so it throws it out of its recomended voltage. Doing so it cuts down the power to the LED and makes it much dimmer. Have you tried to use this setup when the headlights are on also?
      03-22-2009, 05:25 PM   #16
nob
Japan
Drives: MY09 E92 M3 M-DCT
Here is other solution.
This way I did the LED angel-eye lighting in my MY09 M3.
The LEDs are placed in correct position.
But, it is a little difficult to install.
http://www.brex.jp/jp/whitering92/
      03-25-2009, 10:32 AM   #17
Boost3dm3
Boost3dm3's Avatar
26
Drives: E92 M3
pictures of the brex unit installed please?
Become a BMW CCA member; please use member #405205 as a reference . Click here to join online
      03-25-2009, 11:42 AM   #18
roycemek
21
Drives: E92 M3
That BREX piece looks pretty interesting. Does it eliminate the H8 bulb all together? How is the brightness?
      03-25-2009, 11:48 AM   #19
SlammedR8
SlammedR8's Avatar
521
Drives: 2019 X5 40i/2020 R8 V10 Spyder
subscribed
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather
2020 Range Rover HSE - Black/Black
2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black
      03-25-2009, 11:51 PM   #20
camaross305
camaross305's Avatar
135
Drives: 2008 M3
This is true..... Im using my circuit and wiring harness on some LED's here soon to have them operate at full voltage and see how it looks.
      03-31-2009, 03:06 AM   #21
Bluesummer
Bluesummer's Avatar
Taiwan
588
Drives: slower than Ayrton Senna
2017 BMW X5M  [0.00]
2015 M4  [0.00]
2011 E82 135  [0.00]
2011 M3  [0.00]
2007 335  [0.00]
subscribed
________
DEPAKOTE SIDE EFFECTS
      04-18-2009, 03:46 PM   #22
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
That is great great work! WOW
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
m3post
