M3 Front Sway Installed
03-16-2009, 03:06 PM | #1 |
Modder Raider
753
Rep 8,633
Drives: M3
I didn't realize until recently that the M3 from sway was that different than the 3 series. I just saw that it was 26.5mm in diameter and it was the same as the 3 series, but the 3 series tapers in the middle where the M3 bar doesn't.
Not only is the front sway different but the bushings are totally different. They consist of much harder rubber and the brackets are even completely different. It was a little harder than I expected because it took a good amount of force to get the lower bushing into the bracket. I actually had to use a rubber mallet to get the lower bushing to clip in. I posted pictures of the bushings and brackets in another thread, but I'll post it here as well. I finished installing it a couple hours ago and went for a quick drive. It does feel a little tighter but I'm sure I'll get a better feeling during the next couple days. Thanks a bunch to Harold from HP Autowerks for meeting up with me again. He always goes out of his way to meet me whenever he's in the neighborhood. The first couple pics are comparisons of the M3 bushing and the 3 series bushing. The rest are the comparisons of bars and installation photos
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
03-17-2009, 09:10 AM | #5 |
161
Rep 7,377
Thanks Mr. 5 for the always perfect pics and description about the changes you are doing! Learning a lot here!
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
03-17-2009, 09:43 AM | #6 |
193
Rep 3,469
Nice! My M3 front and rears go on tomorrow. Also, the tension rods will be going on as well It should feel like a new car
I just got it back yesterday after some warranty work. I was so glad to have it back
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled) 2020 Car-less 😁 (no more) 2020 M340 |
03-17-2009, 03:17 PM | #7 |
104
Rep 1,040
hmmm, i wonder if you can use those m3 brackets and/or bushings on e92/3 sway bars?
but then again, the m3 rear sway is 20mm while the e93 is 15mm so i guess it wont fit...
03-17-2009, 03:58 PM | #9 |
Modder Raider
753
Rep 8,633
Drives: M3
You can if you want, but why not just get the better bar?
03-18-2009, 02:01 PM | #10 |
104
Rep 1,040
i would have gone with the M3 front and rear sway bar but the new performance suspension comes with the newer front sway already.
so im not sure if i want to combine that front sway with the M3 20mm rear or the e93 15mm rear sway.
