Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Sport suspension upgrade
      03-15-2009, 05:18 AM   #1
wig
wig's Avatar
Drives: 328I
Guys,
I'm ready to upgrade my sport suspension on my 08 E90 sedan and
needs some advice on what to get? Street use only and no tracking.
Mods consist of BMW performance intake, Rogue exhaust, RPI air scoops
and Alufelgen CSL's. Will lowering make the car make it bumpy, if not may
consider it. Thanks again for your help and I'm clueless when it comes to
suspension.
Wig
      03-16-2009, 04:26 PM   #2
SV Concepts II
SV Concepts II's Avatar
269
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
A spring and shock combination (e.g. H&R Sports springs with Koni FSD Shocks) or a standard single adjustable coil over kit (e.g. KW Variant 1) would be your best bet. These setups will give you a lower stance and a firm ride without sacrificing ride quality or comfort.
      03-17-2009, 04:52 PM   #3
wig
wig's Avatar
Drives: 328I
I hear the terms quite often but what are the difference between coilovers
and shocks/struts?
Thanks,
Wig
      03-17-2009, 04:57 PM   #4
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
i just installed Bilstein PSS10 and set on softest, the ride is fantastic, comfort as before if not better because of less roll, car is very well balanced and stable but planted. Even my Gf thinks is much better that before.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      03-17-2009, 06:12 PM   #5
nicknaz
nicknaz's Avatar
3188
Drives: C6Z
If you won't track the car you won't notice a difference other than looks. switch to non run flat tires if you want the ride to be comfortable and go to a lowering spring that is made to work with the stock dampers, such as tein style master
      03-18-2009, 02:49 PM   #6
SV Concepts II
269
Drives: E90 M3
and shocks/struts?
Thanks,
Wig
In most instanced when you hear coilover on the forums, what is being referred to is a shock with an adjustable spring perch which allows you to adjust ride height. KW, Cross, and H&R all make coilovers in addition to their springs and shocks.
Spring and shock/strut combos are non-adjustable. Like your stock setup except with different spring rates and shock valving.
      03-21-2009, 01:08 AM   #7
PNF
PNF's Avatar
Taiwan
167
Drives: 15' YMB F80 M3
how low are koni shocks + HR sports since they are not adjustable?
Thanks
Also, it seems to me that there are 3 major brands that people here uses
KW V1 / ST V1 / FK silverline / H&R
read some complaints on H&R.. so how about others? other than their price difference....
Also looking to enhence the look more than to track the car without sacrificing too much comfort..
2015 F80 Fully loaded (minus the CCB) YMB M3 / Individual Amaro Brown
BBS | KW | Vorsteiner | IND | Akrapovic | BMW CF Performance Interior | Brembo | Eibach
2008 E92 335i (sold)
      03-21-2009, 02:37 AM   #8
dukevi
BMW Noob
35
Drives: E90 328i 2007 TiAg
I went with KW V1... I'll keep you updated...
I just ordered CSL from Alufelgen also
Black/White Roundels, CF Interior trim, Blackline, Matte Black Grille, CF OEM Front Splitter, CF Mirror cover, M3 Spoiler, Alufelgen CSL Gunmetal, KW V1, 55% Tint all around
http://www.e90post.com/forums/showthread.php?t=257325
      03-23-2009, 06:06 PM   #9
SV Concepts II
269
Drives: E90 M3
Thanks
H&R Sports will get you roughly a 1.2-1.5' drop. Have you considered Eibach Pro-Kits with Koni FSD's? This will drop the car about 1.4'' and still provide a comfy street ride.
      03-25-2009, 01:10 PM   #10
PNF
PNF's Avatar
Taiwan
167
Thanks.
I went with KW V1 instead, but I am regretting a little bit, because I was reading the other thread of KW V3 problems on Xi, and not sure if the same failure would apply to V1 on "i" cars, which is what I have.
PS. someone gotta ban this learn chinese dude. I actually accidentally clicked the link and it linked to some place i cant load and i just closed it quickly. probably virus or something
      03-25-2009, 01:54 PM   #11
SV Concepts II
269
Drives: E90 M3
Thanks.
You won't have any issues with the V1's. Good choice by the way, the adjustable ride height is always a benefit.
You too can learn Chinese in China, or even learn American in America.
