BMW performance brake kit not for 335i?
03-13-2009, 06:43 AM | #1 |
94
Rep 1,184
I am considering to put BMW performance brake kit (originally intended only up to 328i) on E93 335i
BMW Performance brakes are the same as the OEM 135i dimension: 338x26mm front 6 pistons 324x22mm rear 2 pistons OEM 335i has 348x30 336x22 but with one piston Do you think that these brakes are a good upgrade for 335i ? Smaller 6 piston is better than bigger 1 piston? It seems that BMW will not release a performance brake kit for 335i because 6 piston 348mm brakes wont fit series 335i 17inch wheels |
03-14-2009, 12:46 PM | #3 |
161
Rep 7,377
the 335 has already very very good brakes. If you want to get more braking power you need to go for a BBK. i am just going to change the front rotors for the looks and change pads, lines and oil all around to increase performance of the original set. Really dont have the cash for a 5-6 K BBK .
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
03-15-2009, 09:06 AM | #4 |
94
Rep 1,184
03-15-2009, 01:34 PM | #5 |
161
Rep 7,377
keep what you have , my 2 cents. For 1000 Euros you can do the upgrade i am doing .
03-16-2009, 06:31 AM | #8 |
161
Rep 7,377
you mean a specific kit for 335i?
03-16-2009, 11:05 AM | #10 | |
just another bmw douche bag
195
Rep 3,640
OP, do not "downgrade" do smaller brakes. the multi-piston calipers may offer more brake "feel", but the smaller rotors will offer less overall performance and less heat dissipation than the stock 335i rotors. |
01-17-2010, 11:12 AM | #12 |
Moderator
618
Rep 10,855
Quick answer: not a good idea, especially for heavy E93. OEM brakes on 335 are excellent for street.
uuni, what have you heard regarding a Perf brake kit for 335? Hey, OT, but I will be in Finland this May for a week and have a couple days to spend touristing. Which town is more fun, Helsinki or Turku?
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
01-17-2010, 01:55 PM | #14 |
132
Rep 1,898
you must really punish the brakes to get fading. I find them really good, much better then the M3 CSL / Z4M, even with the original pads. Only issue is the pads wear fast when they get hot, but still no fading. Make sure you regularly change your fluid!
Changing to the smaller performance brakes is a downgrade, don't do it. Take some good pads instead. If you are really tracking, then you will have to invest in a BBK. |
01-18-2010, 01:06 AM | #15 |
22
Rep 630
Drives: 2009 BMW 335i coupe
I agree with above. My plan is for new rotors, new pads and painting the calipers. As long as you're not flogging the car on the track, the OEM calipers are fantastic. Fluid could be changed out as well, Red Line is probably what I would throw in.
2007 Porsche Cayman S
01-18-2010, 02:32 PM | #16 | |
263
Rep 2,559
I agree with Tony (and enrita) - either keep your OEM discs and upgrade to steel lines and better pads, or go all the way with a BBK. The BMW Performance brakes are not intended to be used with our car, and the E93 is 200kg heavier again than the E90/E92, so it will not be an improvement. Tony trashed the Performance brakes in one afternoon at the 'Ring, IIRC. Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
01-19-2010, 12:24 AM | #17 | |
99
Rep 1,050
I've been there and done that. The stock brakes are very good and the 135 brakes aren't as great as you're lead to believe. I have experience with them both plus a Stoptech BBK, all on the track under hard braking on the same tracks. |
01-19-2010, 02:52 PM | #18 | |
Moderator
322
Rep 5,493
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
01-19-2010, 04:48 PM | #19 |
Moderator
618
Rep 10,855
Meh, I heard the stig melted a set in only 3 laps...
