Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Need cheaper tire options
      03-09-2009, 10:59 AM   #1
yazans
Drives: 2007 BMW 328 Coupe
Hi, The time has finally come to change my stock tires for my 2007 328 coupe with sports package, I have plugged the right rear tire three times and now I have to fill it up with air every 3-4 days (does not sound very safe)
I have no interest in getting bigger tires, just the original stock size.
Front: 225/40R 18 88W RFT
Rear: 255/35R 18 90W RFT
I got 21k miles out of them which is not horrible but not good either.
All I can find on discount tire is the Bridgestone Potenza RE050A Run Flat and the Pirelli PZero Run Flat, both very expensive solutions.
One mechanic suggested I just get non RFT, any recommendation?
Do I really need RFTs? Is there a cheaper solution out there where I don’t have to worry about getting a flat tire and get stranded since I don’t have a spare tire?
Once tires are purchased, is there an advantage of having my 4 wheels aligned at a BMW dealer vs somewhere else? Any recommendations?
Thanks a lot
Yazan
      03-09-2009, 01:56 PM   #2
shift330
Blue Force Tracker
shift330's Avatar
124
Drives: 2010 Hyundai Genesis Coupe
2006 330i  [0.00]
I got 19" Nexen N7000 tires for $99 each. The tires on my last set of wheels were 18" Falkens and ran about $180-$200 each. Dont stick with run-flats - they really suck.
Stay safe 855th MP Company! Hosmer/Espinoza you're my boys!!
      03-09-2009, 02:21 PM   #3
yazans
Thanks shift330 for your reply,
But what did you do if you got a flat tire? Did you keep a spare?
      03-09-2009, 02:31 PM   #4
mikeokimster
205
Drives: e90 jerez m3
Here is my plan. I may end up getting a spare.
I am nearing the point in which i need to replace the oem runflats. I have about double the thread life left on the front tires so I will replace the rear ones for now.
Key elements:
1. Price
2. Noise
3. Traction
4. Tread wear (at least 25k miles)
5. Wet traction
Here are the choices I have narrowed down to(ranking determined by factoring in tirerack surveys with my order of key elements):
1. Bridgestone Potenza RE960AS Pole Position $224 R (ea) + shipping (265x35x18 is closest) [400AA A]*
2. Yokohama Advan S4 $221 R (ea) + shipping [400AA A]*
3. Pirelli Pzero Nero M&S $208 R (ea) + shipping [400AA A]*
4. Goodyear Eagle F1 All Season $188 R (ea) + shipping [420AA A]*
5. Michelin Pilot Sport A/S Plus $250 R (ea) + shipping [500AA A]* <- No survey info so defaulted last
I am concerned about the Goodyear Eagle F1 allseasons wearing too quickly. Prices are all from Tirerack.com. According to the survey results, the Yokos performed very similar to the Bridgestones Potenza's. Bridgestone's seem to have a slight adantage in tread wear to the yoko's.
*Note: I know the UTQC ratings are manufacturer dependent, leading to possible inconsistencies in tread life.
Current: 10' E90 Jerez M3 DCT
///Mods: Xpel front clip wrap, Nokya 2500k H8 halos, matte grills, IND reflectors, scoops, MS drop-in, MS track pipes, Dinan exhaust, 240E, ESS tune, BBS CHR, s04 255x35 295x30, KW Clubsports, ceramic pads
Retired: 08' E92 328i JB 6mt 212 rwhp 190 rwtq
      03-10-2009, 02:31 PM   #5
shift330
Blue Force Tracker
shift330's Avatar
124
2006 330i  [0.00]
No spare. If I get a flat I can just have a tow truck pick it up or go get my truck and load it on a trailer to bring it home.
      03-10-2009, 03:56 PM   #6
SuPaSkillz
SuPaSkillz's Avatar
Drives: 2008 e90 335i /2007 E63 M6
I've never liked sumitomo tires...but they seem to have stepped it up with there newest tire the HTR III...they have recieved very good reviews and seem to be alot better than the runflats we get stuck with on all bmw's (none M) and are pretty cheap compared to others that dont perform as well...check them out at tirerack.com
      03-10-2009, 04:06 PM   #7
nomile
Drives: 328xi; 318ti
I'm going to switch to go-flats without a spare. I'll probably get a slime-kit (the $30 one - has a compressor and is supposed to be TPMS safe). Furthermore, with my old car I found the following to be true: If you keep your tires maintained (check pressures, swap at 2/32nds, etc) you'll likely only ever have a problem with a nail/screw in the tire. Blowouts are EXTREMELY rare (if tire is maintained). Thus if you have a nail, TPMS will tell you and you can fill the tire (with slow leak) and drive to a tire shop the next day.
My previous car (318ti) had 2 or 3 flats over the course of 12 years, and they always fit this model. Never had to pull the spare.
My $0.02
Tags
bridgestone, cheaper, rtf, run flat, tires
