Studio RSR
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > SPONSORS Classifieds/Groupbuys/Specials Area > Turbo Engine / Drivetrain / Exhaust Parts > [GT Motoring] Forge MotorSports Recirculation Valves for 335/135/535!!
      03-04-2009, 09:38 PM   #1
GTM
GTM's Avatar
68
Drives: E92 M3
GT Motoring is the Forge Motorsports distributor.
Forge has been producing high quality BOV/BPV parts for many years.
This is Recirculation Valves for N54 twin turbo engines.
Retail : $335
Thank you!!
-------Product Info-------
Developed specifically for BMW’s all-new N54 twin turbo motor, as found in the BMW 135,335 and 535 models, Forge Motorsport adds another replacement valve application to our already extensive vehicle specific and universal valve lineup.
While virtually identical in operation to the Bosch style valves as used from the factory on many other turbocharged applications, primarily Volkswagen and Audi, BMW has utilized a very different type of valve connection mechanism that makes their product and our replacement components very unique.
Starting with the world’s best selling direct replacement Bosch style valve, our own 007P piston-based design, we have revised virtually every single component of the valve body, (except the internal piston), in order to retain BMW’s unique connection mechanism yet offer improved functionality in every other possible way.
The entire valve assembly is precision CNC machined from T6-6061 billet aluminum alloy on our very own Mazak CNC milling machines.
Again, the valve is an aluminum piston based design, offering significantly improved reliability over the failure prone OEM diaphragm valves, yet with no change to valve response time.
We utilize ultra high temperature Viton brand silicone o-rings for sealing and Mobil1 fully synthetic bearing grease for lubrication.
The valves are fully tunable for both boost holding capacity and response by way of proprietary interchangeable springs and shims (washers to marginally adjust preload).
By utilizing this method of valve tuning with multiple custom spring rates, the valves will retain the maximum range of piston travel and flow volume regardless of which spring rate is used.
Valves with a singular spring requiring that adjustments be made by continually adding preload will suffer from decreased piston or diaphragm travel as the spring tension is increased.
Though these types of valves may hold high boost levels under load, they will actually suffer from limited flow volume at throttle lift when the valve vents.
The hoses included in the kit are a custom made multi-layer fabric reinforced flexible silicone hose that are designed to allow compatibility with the stock airbox and charge piping setup without any permanent modification being required to adapt our replacement valves.
Even the included hose clamps are overkill.
They are specifically designed for use with silicone hoses, utilizing a beveled band edge and a pressed in drive mechanism rather than perforated.
They are even approved by NATO for international military use.
All told, this direct replacement valve kit will be suitable for a bone stock car to one that is heavily modified.
They can be installed on the car right on the showroom floor and they will last well past having upgraded your intake, exhaust, and ECU software.
They are capable of handling an infinitely wider range of boost pressure, more reliably, than the OEM valves, and they carry an unlimited lifetime warranty and money back guarantee.
      03-04-2009, 09:59 PM   #2
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
634
Drives: BMW M3 | X5 xdrive 35i MSport
very nice.. i know where i will be going once when i get my car
      03-06-2009, 12:20 PM   #3
GTM
GTM's Avatar
68
Drives: E92 M3
Thank you!
      03-06-2009, 08:29 PM   #4
BlueLion
she likes the flavor......
85
Drives: A51-E92
2022 X3MC  [0.00]
price?
E92 Montego Blue silfa718 ..::STETT CAI|ADVAN RS|WAGNER FMIC|MS DP|VANGUARD|PROCEDE|FORGE DV|BMS OCC|KWV2|MICHELIN PSS|OOS::..
      03-07-2009, 06:41 PM   #5
GeorgeSmooth
GeorgeSmooth's Avatar
38
Drives: 2008 E90 335i AT
PM Sent
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63
      03-09-2009, 02:03 PM   #6
GTM
GTM's Avatar
68
Drives: E92 M3
PM replied.
      03-09-2009, 07:46 PM   #7
theblackmamba
78
Drives: 0
Why are these like $100 more than ones posted in teh other thread?
      03-10-2009, 11:52 AM   #8
GTM
GTM's Avatar
68
Drives: E92 M3
Price LOWERED!
$245 shipped!!
      03-11-2009, 03:25 PM   #9
E92NV
12
Drives: E92 alpine white
does it come with the pipe too?
      03-11-2009, 09:35 PM   #10
GTM
GTM's Avatar
68
Drives: E92 M3
Yes it comes everything pictured above.
      03-11-2009, 09:52 PM   #11
Septro
77
Drives: '08 e90 335xi
I installed a buddy's and both his hoses were the same size and were somewhat tough to have enough room when installed with a DCI. The picture looks like one is bigger than the other - will they ship that way?
      03-12-2009, 03:36 PM   #12
GTM
GTM's Avatar
68
Drives: E92 M3
Both are same size.
      04-01-2009, 10:26 PM   #13
MarinoB
MarinoB's Avatar
Croatia
282
Drives: '17 F80 M3
do you have them in black?
      04-02-2009, 10:52 PM   #14
GTM
GTM's Avatar
68
Drives: E92 M3
Sorry we dont.
      04-06-2009, 03:26 PM   #15
E92NV
12
any sound clips of these?
wtb: tial bov w charge pipe, Injen intake
      04-11-2009, 05:10 PM   #16
BuLoOoSki
Kuwait
749
Drives: 2015 BMW M3
how can i buy these at the price above, i went into the website and it still says $335 over there. please PM me link on how or where to buy these at the $245 price. thanks
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs
Search this Thread:
Advanced Search
