Difference between KW V1 for E92 and E90
03-04-2009, 08:03 PM | #1 |
33
Rep 671
I know the E92 KW V1 can fit on the E90 and vice versa. But, what exactly is the difference between the 2? Does anyone know?
03-06-2009, 10:40 AM | #2 |
Rep 20
The only difference is that the E92 KW rear coilovers have a 35mm bump stop.
The E90 KW rear coilovers have a thicker 50mm bump stop. This is probably because the E90 is expected to carry more rear passengers and luggage than the E92. The thicker bump stop accomodates for the extra weight. |
03-07-2009, 02:53 PM | #3 | |
33
Rep 671
03-07-2009, 04:34 PM | #4 | |
95
Rep 1,659
03-09-2009, 11:30 AM | #5 |
Rep 20
Compare the KW2 specs for e90 and e92 here.
http://www.kw-gmbh.de/kw_upload/Guta...07-1573-N1.pdf http://www.kw-gmbh.de/kw_upload/Gutachten/ga06-3958.pdf I assume the same difference applies to KW1. |
03-09-2009, 11:34 AM | #6 | |
Rep 20
Thicker bump stop also means shorter travel distance for the shock. |
03-10-2009, 11:46 AM | #7 | |
33
Rep 671
Im a suspension newb. What would be the effects of shorter travel distance for the shock mean? You think it'll make any difference if i got a e90 kw v1 for my e92? |
03-10-2009, 02:19 PM | #8 |
58
Rep 2,201
Drives: 996TT/ae86
The E90 & E92 coilover for either model is the exact same components there are no differences. So if it says E92 on the box it works on your e90 or vice versa.
03-14-2009, 09:15 AM | #10 | |
Rep 20
KW's specifications (see PDF links above) clearly specifies a 50mm bump stop for E90 and a 35mm bump stop for E92. I'm sure this makes no practical difference for 99.9999% of users. I'm using an E92 kit for an E90 myself. |
