who sells KW camber plates?
02-19-2009, 08:12 PM | #2 |
30
Rep 621
Anyone? I'm interested in these as well.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
02-19-2009, 09:42 PM | #4 |
111
Rep 1,764
If you go this far then you can covert you KW v3 into a true Coilover with good quality 60 mm Swift spring. You will be amazed how much softer your ride is with the same spring rate. The range of the dampers are 570-900 lb/in in the rear and 285-400 lb/in front. It has just as much range as TC Klien.
You can order any of the KW part from any reseller and they take about 2-3 days to get. Camber Plates: 19000776 – KW e9x Camber plate assembly, left, Qty 1 19000777 – KW e9x Camber plate assembly, right, Qty 1 Lower camber link spring seat: 65243336 – Lower Spring Seat, Qty 2 ($6.00) Orb Last edited by Orb; 02-19-2009 at 11:09 PM.. |
02-19-2009, 10:49 PM | #5 |
30
Rep 621
Thanks for the info Orb. One question, are these the same part numbers for the e82?
02-20-2009, 07:15 AM | #7 | |
52
Rep 986
Thanks Orb! Is there a specific Swift Spring you recommend? I checked the website for swift springs and couldn't find the right application. I have KW V3 and Quaife LSD as well. will be getting M3 rear guide rods, front tension struts and wishbones and maybe roll bars. Last edited by tomtom; 02-20-2009 at 12:44 PM.. |
02-20-2009, 01:11 PM | #8 |
52
Rep 986
called KW. no camber plates for e92 KW V3 and those part numbers don't come up. but if i went with linear springs can use M3 plates. cost is $450 each...$900!
are they that much better than vorshlag? KW linear springs go for $120 each (510 fronts and 800 rears). how much for swift springs? |
02-21-2009, 02:05 PM | #9 | |
111
Rep 1,764
As for springs, you have to pick your won which is the whole purpose of 60 mm springs. The Swift spring sell for about 85.00 to 100.00 each. The helper springs are about 1/3 less. As for Vorshlag, they are the wrong stack height so live with the junk they give you for lower cost or buy the correct parts. The KW camber plates are a much better design than the Vorshlag and the stack height is correct and they don’t make noise. One fits correctly the other doesn’t. Orb Last edited by Orb; 02-22-2009 at 09:50 AM.. |
02-22-2009, 09:11 PM | #10 |
52
Rep 986
sam at autotalent didnt even reply,
KW NA didnt have any knowledge of camber plates for 335i. ill try KW Germany. I wonder why KW with progressive springs? if linear are so much better. surely they have put big$$$ in R&D. any swift spring vendors in canada? |
02-22-2009, 10:48 PM | #12 | |
Go big or go home!
53
Rep 948
05-14-2009, 04:13 AM | #14 |
86
Rep 1,166
anyone knows where to get camber plate for the KW V2?
325i Arctics M-Sport, Gray Leather with Alu Trim, ///M DCT Paddleshift, ///M Gear Knob, BBS LM-R 19", Michelin PS2, KW V2, H&R Anti Roll Bars, BMW Performance Air Intake System, 3D Front Lip, ACS Roof Spoiler, OEM Boot Spoiler, Osram 6000K, Brex White Ring, PIAA 6200K HID Fog, PIAA License Plate LED, BMS Powerbox
05-18-2009, 10:36 AM | #15 |
Air India
145
Rep 1,834
get camber plates from Turner Motorsports. They should work for the KW's
i plan on getting the vorshlag ones. http://www.vorshlag.com/product_info...b529474997a071
PKumarM3 |
05-18-2009, 11:26 AM | #16 | |
111
Rep 1,764
The Vorshlag plates are junk as they don't fit right. The stack height is wrong and the nuts hit the tower and brace. They also make a lot of noise. This is what you get when you try to make e36 camber plate and use it to fit another application...it is called a hack when one doesn’t even check. They have tired to fix their plates twice but have failed to do it right. This is what happens when someone pretends to be an engineer….incompetence. The KW plates fit perfect and make no noise so that is why people ask for them. Orb |
05-19-2009, 01:41 AM | #17 | |
Air India
145
Rep 1,834
I have used many of the Vorshlag products on my E46 M3 and they have worked beautifully. The camber plates are ones that are used all the time w/moton suspensions. Their strut bar is a nice piece of work made by John Mason of Mason engineering. I have their motor mounts and tranny mounts on my race car as well.. The owner of Vorshlag was one of the people that started/head engineers at Koni, that eventually split into Moton/AST/Ohlins. I would not say that they are incompetent or are "pretend engineers" Noises are inherent with RACE components on street cars. Take a ride with me in my E46 race car and you will understand what "noises" are. Fitment is another issue and I have done research on this forum, but I guess I haven't gone through the "Vorshlag Camber Plates suck" threads. The KW Plates should fit perfectly, but the no noise, could mean a few things as well. Either way, thanks for your opinion, as I value all views of a story!
PKumarM3 |
05-19-2009, 07:36 PM | #18 |
475
Rep 13,583
Drives: JB E92 335i
If you get the clubsports they come with them.
Since I see you are having a hard time finding them - us as well as any of the authorized KW dealers can get you the camber plates. Here is a link to your authorized KW dealers: http://www.kw-suspension.com/en/60_D..._USA/index.php |
05-19-2009, 11:18 PM | #19 | |
111
Rep 1,764
Honestly, this is almost to funny as it just doesn't happen in any other field. Yes the bearing is lose in the cup....makes for good clicking sounds. You got to love the extra chips is comes with as well. Last edited by Orb; 11-25-2011 at 12:09 PM.. |
