02-07-2009, 11:27 PM | #1 |
34
Rep 381
Drives: BMW 128i
debadging - how to remove glue residue?
I'm thinking about debadging my car tomarow, did some research on this site, and figured that the best way was to use a hair drier, and some dental floss, the only problem is i don't have any goo gone to remove the adhesive glue, does anyone know anything else i can use to remove the glue?
02-07-2009, 11:40 PM | #2 |
204
Rep 2,229
when I put on my shadow emblems there wasn't THAT much risidual adhesive left, your finger nail and some soap and water will probably do the trick. But goo gone isn't that expensive and at least you'll have it on hand if you ever need it
02-08-2009, 12:16 AM | #3 |
_
152
Rep 426
3M adhesive remover also works, it's much cleaner than googone which can leave a greasy feel. BE SURE TO NOT OVERHEAT THE BADGE!!! I'd also wax the area after you debadge. Just a little fyi.
02-08-2009, 12:55 AM | #5 |
Rep 137
A little 3M rubbing compound on a hand-towel will get all the residue off with about 10 seconds of brisk rubbing.
SGM 135i - M-Sport - Cld Wthr - Blk 'Ette - iPod - HiFi - Grey Poplar - Riss Racing Intake - cp-e Exhaust - DINAN Stage II
02-08-2009, 01:00 AM | #6 |
エアーマンが倒せない
268
Rep 2,041
Are there alignment holes that need plugged after the removal?
02-08-2009, 01:06 AM | #7 |
Rep 137
Nope... they are just held on with basic 2-sided foam tape. Takes 5 minutes, max.
02-08-2009, 01:56 AM | #8 |
Proud 1er
24
Rep 699
I took off the 135i today and put on black ones. It was not real warm and there was no sun, so it was a bit of work. I didn't apply heat because I was using masking tape to mark where the original numbers were and I didn't want to risk messing that up, so it was a real pain getting the adhesive off. Goo-gone didn't do much for me, and so I resorted to some carefully applied WD-40. But I bet heat would have made a difference.
02-08-2009, 02:47 AM | #9 | |
51
Rep 905
02-08-2009, 05:40 AM | #10 | |
103
Rep 1,254
02-08-2009, 09:38 AM | #13 |
34
Rep 381
Drives: BMW 128i
Thanks for all the information guys looking foward to doing this today, hope i don't mess anything up, im going to use a hair drier since its RI weather and we have no sun out, some dental floss, and gonna try a few methods to remove the glue, using some tape and some WD42 soap water and some wax
02-08-2009, 09:54 AM | #14 |
Good life
130
Rep 1,936
Just use "Tarminator" spray. It's meant for road tar and bugs but it's safe on painted surfaces. I used that when I debaged my STI. Worked beautifully and cleaned the surface as well.
02-08-2009, 10:08 AM | #15 |
Most interesting Roadster
69
Rep 2,224
Drives: '01 Z3.0 Roady;'10 C300 Sport
I'm taking mine off for the nice clean look it provides. The only badge you'll see on the back of mine is the BMW roundel.
I can't complain, but sometimes I still do........Life's been good to me so far.
- Joe Walsh |
02-08-2009, 10:09 AM | #16 |
209
Rep 959
any pics of debadged cars?
02-08-2009, 10:37 AM | #17 |
29
Rep 769
Aesthetics mostly. I think it looks much cleaner without a tag on one side of the back. I debadged my last 3 series (it was much more popular to do it back then) and I think I'll debadge my 135i. If I eventually do get an M3, I'll debadge that as well!
02-08-2009, 11:02 AM | #19 |
34
Rep 381
Drives: BMW 128i
Just debadge my car, worked out pretty well, had some trouble removing the glue residue, i used my finger nails, and a sponge, wasn't thinking, and it was definetly not a good idea, dont know why i did that. But after i use some soap wax, and WD40 to finish off it came out good, but i probably need to buy some goo gone to finish it off later.
02-08-2009, 12:56 PM | #21 |
Proud 1er
24
Rep 699
