02-01-2009, 03:32 PM | #1 |
39
Rep 962
headers
ok i am going to be buying ebay headers.. for those of you have have headers installed on your m coupe i have a quick question about the o2 sensors. It is to my understanding that all 4 o2 sensors don't fit in to the bungs. So with that being said, all i have to do is install the pre cat sensors in the post cat bungs, and leave the post cat sensors out. all the post cat sensors do is test for emissions. The pre cats are for the a/f ratio.I will get a ses light by doing that, but i will most likely do a tune.
Correct me if i am wrong.. thanks
02-01-2009, 05:06 PM | #3 | |
218
Rep 4,726
Don't consider it an option. But you have the rest right. If you get ebay headers do yourself a favor and supply OEM gaskets to the shop that installs them. And make sure they aren't idiots and know which direction the gaskets go on, and not to mix up your O2 sensors/plugs, and not to twist the wiring getting them in/out. And test fit them before bolting them in so they know what to cut. And a bunch of other stuff :/
02-01-2009, 05:28 PM | #4 |
39
Rep 962
i have done header installs before. so i will be doing the install myself. and yes i will do a tune, i don't know why i said most likely. and of course i am going to buy oem gaskets and hex nuts the ones that come with it are crap.i am going to label the o2 sensors so that i won't get them mixed up... i read to many threads where idiots mixed up the o2s. Also read one that cracked me up. some guy didn't think he needed the 02 sensors at all so he didn't even install them.. anyway, yes i know not to twist the wires, but what is need to cut, bungs??? i can't imagine anything having to be cut besides that. is it that it doesn't get directly put in the exhaust flow, or is it clearance issues of it hitting something???
02-01-2009, 05:31 PM | #5 |
39
Rep 962
m3forum had all you could imagine.. i would like to but i don't think i have the time to go and get the car dynoed.. sorry
02-01-2009, 08:11 PM | #6 | |
218
Rep 4,726
I have a long standing bet that some of the ebay headers are sold by supersprint because you would seriously have to try to mess up what is messed up about them.
02-01-2009, 08:22 PM | #7 |
39
Rep 962
i don't understand what you are saying...
02-01-2009, 10:03 PM | #8 |
88
Rep 1,090
I think he might mean get the headers semi in place and held on by a couple bolts and see if the O2 sensors line up with the bungs.
Let us know how is goes.
135i N54 manual
MR-S with a 2zz swap and mods Sold EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold |
02-02-2009, 07:04 AM | #9 |
39
Rep 962
ok... i read the diy on m3forum, they but the o2 sensors in before they put in the headers... yea i will let you guys know how i end up. ill report back if i run into problems that i can't resolve myself..
02-02-2009, 02:55 PM | #12 |
39
Rep 962
oh thats good to know. ill see how it goes.
02-14-2009, 01:23 PM | #13 |
39
Rep 962
just thought i would report back... i have the oem headers removed, and test fitted the ebay headers, i will be able to get all 02 sensors and the egt sensor in. I will just have to grind down the rear header post cat bung a little bit to allow a little room for clearance. i now fully understand what the alignment problems are. i have to go to work now, that is why i didn't finish the install, but i will finish tomorrow and ill report back again.
02-14-2009, 01:39 PM | #14 | |
218
Rep 4,726
You see what I mean about the flanges fitting now and the thickness? Also I hope you picked up OEM gaskets too.
02-14-2009, 08:22 PM | #15 |
39
Rep 962
i picked up oem gaskets and nuts, yeah the alignment on the fronts is pretty bad but ill get it. the rear slips right on. the sensor near the egt bung and the egt don't touch, there is plenty of room there. it is just the rear headers post cat bung that bothers me. ill just grind it down. it will fit as is, but i don't like it that close to something, i just want that extra clearance. the flanges are actually really thick, i am worried that i might have to buy longer studs tomorrow.
02-14-2009, 10:25 PM | #16 |
53
Rep 689
thanks for the update...good luck. Be sure to post a sound clip. Also, what section 1 are you running?
2007 M Coupe w/NAV/Premium/Extended Leather, Clearbra, DICE, 4.10 BMW Motorsport Polished LSD, Active Autowerke Gen IV Headers, Supersprint Race Exhaust and X-Pipe, ESS Tuned DME, KWV3 Coilovers, Volk RE30, OEM Strut Tower Brace, Short Antenna, JL AMP, JL 10W7, Valentine V1.
02-15-2009, 04:02 PM | #18 |
39
Rep 962
today i installed the headers, i got everything on, labeled all of the o2 sensors. I am running in limp mode. the pre cat 02 sensors are in the pre cat bungs, i couldn't get the post car sensor in the rear post cat bung. so i am running no post cat sensors. to my understanding i don't need the post cat sensors to run the car. please need help.
02-15-2009, 10:23 PM | #21 |
218
Rep 4,726
I told you you HAVE to have a tune to do this.
With the post cats out you will get an immediate CEL for the sensor heaters being inoperable. Even if you were able to plug them in (I told you you wouldn't) fairly quickly you would get a CEL for catalytic efficiency. (and would lose a good amount of power) I know I'm a dick a lot of the time, but when I say things I'm not fucking around.
02-15-2009, 11:15 PM | #22 |
Rep 257
O-Cha, I am not contesting you're knowledge, but I am running the headers without software and can tell you I have no problems. I do not have dyno sheets for proof, but I can tell you how I compare before and after next to my nephews tuned 335i. Before the headers, we were nearly dead even. Typically he pull a nose ahead, and rarely I would pull a nose ahead. The day after I picked my car up we did some pulls. This time I pulled at least half a car every time. Sometimes a car length or more (especially if we ran up past 130). This was all with my 115 pound GF in the car while he had no passenger. I definitely didn't lose power, but my gas mileage sucks ass and the car back fires like a motherf*cker. I know this doesn't help the OP directly, but I just want him to know that the car can run without software. Maybe recheck the O2s?
ESS Tuning Software, JVT (Ebay) Headers, AFE Intake, RPI Scoop, ACS Pedals, and ZHP Shift Knob.
