01-31-2009, 03:41 PM | #1 |
62
Rep 657
135 at Roebling Road
Anybody had their 135 out on Roebling Road yet?
I'm trying to decide whether to take my 135 or the old M3 to an upcoming lapping day. |
02-01-2009, 02:03 PM | #2 |
Rep 204
As much as I'd liketo say 135, the M3 would probably be more fun. As long as it's able to take the abuse (10+ year old car)the M3 is the better track car. I did a lapping day there last year and it was a blast.
02-01-2009, 03:15 PM | #3 |
62
Rep 657
The M3 probably has over 3000 miles at RR. I'm sure it would be quicker, but I would like to try the 135 sometime. I just hope it doesn't plow so much that I just grind off the front tires.
02-02-2009, 08:43 AM | #4 |
Rep 204
I think you know the answer then. Take the 1 and report back on how she does. I'm sure the 1 will understeer more than the M but it's still better than 90% of the cars on the road.
02-13-2009, 02:35 PM | #5 |
62
Rep 657
Lessons Learned from Roebling in the 135. (Long)
1. I still prefer a normally aspirated motor for track duty. The N54 pulls deceptively well, but the power is difficult to modulate at the limit. This may be due to BMW's drive-by-wire throttle programming, which exaggerates the initial throttle opening. While feathering the throttle through Roebling's long, steady state corners, very small changes in pedal position caused the front end to bob up and down, causing lots of understeer. I do not have any type of tune or suspension upgrade on the car (yet).
2. I am now convinced that a LSD is needed to get the most out of the 135. I tried normal, DTC, and e-diff modes, and I could sense the brakes being applied under corner exit in all modes to some degree. I didn't think it would be a problem for high speed (3rd gear or higher) corners, but it was. Perhaps with less body roll (suspension upgrade) this could be minimized. 3. The stock run-flat tires, in spite all of the bad press they get, have a surprising amount of grip. I was able to take most corners at indicated speeds within 3-4 mph of what I can in my M3 with full track setup (suspension, tires, alignment). Understeer was a problem in some corners (T1 and T6), but in turns where I could keep the power on (T3 and T9) the weight transferred rearward and the the car just stuck. FWIW, my Ipod Dynolicious program indicated a maximum of 0.97 G's left, 0.98 right, and .99 under hard braking. 4. No problems with oil temp with 78 degree ambient (in February!). Maximum observed temp was 260. 5. Sport seats are pretty good. Not race seats by any means, but good. On the same day, I drove a '08 Z51 Vette (on track tires) and the seats in that thing are a joke. I've used barstools with better support. I couldn't drive that car well because it required use of two of my four limbs just to stay in front of the wheel. I can't believe GM doesn't offer a more peformance oriented seat in a car that has so much capability. 436 horsepower makes a difference. 6. After 150 miles, the left front tire is toast. Roebling is very hard on tires because you are almost always turning. I did reasonably well in the AM trying not to abuse the tires, but later I "had" to push hard enough to outrun the 335 that was also there, as well as push the Vette some. Ego can be a terrible (and expensive) thing! 7. Brakes went a little soft early in the day, but came back and stayed solid the rest of the day. Braking into turn 1 is from 140, but that is really the only time the brakes get a workout at Roebling. I believe more front tire would help braking performance. 8. My lap times were 5-6 seconds slower than in my M3, much of which came in T1 and T2 where the 135 understeered pretty heavily. I just had to back off and wait for grip until I could power out of T2. I was less than a second behind the Vette, so it wasn't a total blowout. Overall, it was a fun day. The car ran flawlessly and held its own against some very capable machinery. It was hard to go back to a street car after being used to a dedicated track car, but it does show how capable modern street cars have become. Now, if I can just pick up a few upgrades with my tax refund like wheels, tires, suspension, camber plates, JB3, etc............ It's a slippery slope! |
02-13-2009, 03:10 PM | #6 |
240
Rep 1,288
Great write up. Thanks for the info and comments!
Yes, these little 135s are quite potent cars in capable hands. As you said, imagine it with a tune, suspension upgrade, track tires, and less understeer. It has a hella lot of potential! |
02-28-2009, 06:57 AM | #7 |
62
Rep 657
Well, I ordered my suspension last night. I decided to try the Cross coilovers. Hopefully, I'll get another opportunity at Roebling so I can do a before and after comparison.
Thanks to Dan at Vivid Racing for helping with the selection process. |
03-11-2009, 08:16 PM | #9 |
62
Rep 657
04-06-2009, 04:56 PM | #10 |
62
Rep 657
Crossed Up
04-16-2009, 01:48 PM | #11 |
62
Rep 657
Cross Coilovers
They are in!
http://www.1addicts.com/forums/showthread.php?p=4929827 I'll provide another update once I get the car back on track for comparison. |
09-11-2009, 10:57 AM | #12 |
62
Rep 657
It only took 5 months, but I finally got the car back on the track.
Update here: http://www.1addicts.com/forums/showthread.php?p=5849329 |
