01-31-2009, 08:45 AM | #1 |
Critical Care Anesthesiologist
481
Rep 8,828
Drives: SMB F83
Be careful with self tapping screws
I installed the OEM aluminum pedals in my car yesterday. The installation was was very easy if you know how drill holes on steel (brake pedal / clutch pedal too). We took a short cut and used self tapping screws for the gas pedal. Immediately after installation, the gas pedal didn't feel right. It has a lot more resistance when I try to step on it. Turns out the self tapping screw in the bottom right corner, closest to the center console, is hitting the pedal mechanism. I removed that screw and now it works fine. I guess I have to replace the screws with the OEM screws and nuts next time I go into the shop.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
02-13-2009, 04:30 PM | #2 | |
_
152
Rep 426
02-14-2009, 02:22 AM | #3 |
80
Rep 2,339
Stupid question but does anyone know what kind of screws you need for aftermarket pedals? I've got unltimate pedals coming but they didn't come with mounting hardware. What kind of screws and nuts are the oem ones?
E90 ///M3/ AW/ Fox Red |
02-14-2009, 12:33 PM | #4 |
514
Rep 5,392
Drives: 08 JB E92 M3
OEM pedals do have any screw... They are wrapped with plastic pieces.
01-28-2016, 09:14 PM | #5 | |
Rep 41
Drives: 2011 E90 M3 Pure
Hoping I can get the self tapping screw out and then cut a bit off or grind a bit off the end. Problem is the hole is going to be a bit off a mess and be slightly more loose. |
01-29-2016, 03:38 PM | #6 |
92
Rep 393
Drives: ///M3
Just use the proper hardware from the get go. It's a car, not a piece of drywall?
Your local hardware store should sell the proper drill bits to drill through steel.
2009 BMW E93 6MT///M3 - SG/FR
2011 BMW E90 DCT///M3 - JB/FR (Sold) |
01-31-2016, 05:10 PM | #8 |
Retired Curmudgeon
2985
Rep 4,047
Heh. I see what you did there.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
