TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Asia > Hong Kong > Tyre Pressures
      01-28-2009, 08:03 PM   #1
K3VMO
11
Drives: E93 AW 335i
Tyre Pressures
Right guys/gals,
Silly question... but heard some random advice from a garage just a few days ago. I'm currently running:
Front: R19/35/235 - Pirelli P-Zero Nero
Rear: R19/30/265 - Pirellia P-Nero Zero
Now I've always assumed the correct typre pressure was 32 PSi. But the other day some random garage was telling me I should be running them at 38 PSi.
That sounds awfully high........ any comment?
      01-28-2009, 09:14 PM   #2
little_croco
little_croco's Avatar
Hong Kong
141
Drives: E90 330i Monaco Blue/Beige
2006 E90 330i  [6.00]
I am not so sure about 19", but I am running my 18" at 40 PSI (280 kPa).
E90 330i VB32 Monaco Blue/Beige/BurledWalnut - Prodrive GC-014I Forged 18" 8.5J/9.5J British Black + Michelin PSS 225/255 + Bilstein PSS10 + H&R ARBs + ACS bodykit + Brembo Gran Turismo Brake Kit 355-6F/345-4R + Rogue Engineering IKON exhaust kit + Simota Intake V2 + MFD Scoops + Blackline w/ red bulbs + PIAA H11 4700K fog + PIAA 6500K White Angel Eyes + MTEC 7000K license plate LED + GS-55 front doors LED + Valentine-1
      01-29-2009, 05:26 AM   #3
Bimmer /E93
In The Flesh
Bimmer /E93's Avatar
Hong Kong
18
Drives: E93 (Sold), Z4 35i on board
I have 19" 235/30 front and 255/30 Rear. Tyre pressure varies depending on temp/season... I run mine at 35PSI front, 33PSI Rear
In general tires lose 1-2 PSI per month in hot weather, you might want to add a +1PSI to your current setup than.
      02-08-2009, 10:34 AM   #4
kcleung
kcleung's Avatar
Hong Kong
Drives: E90 323
think manufacturer usually quote cold psi numbers, if you want to be clinical abut this, get a pressure gauge and a pump. you might want to consider nitrogen as well.
BMW Performance Brakes
      02-10-2009, 10:37 PM   #5
M_M
Drives: 335i
40psi? you needa go to an autocross very often? j/k.
      02-11-2009, 02:17 AM   #6
SnowHill
SnowHill's Avatar
Hong Kong
22
Drives: Old: E90 330i; New: F20 M135i
2006 E90 330i  [0.00]
2003 E46 318i  [0.00]
yes, 40!?
isn't it too high?
u didn't feel slippy ma???
      02-11-2009, 07:38 AM   #7
Minichamps
Drives: E91 330i Delivered June 27 '07
Does anyone check this label?
http://www.convertunits.com/from/bar/to/psi
      02-11-2009, 08:25 AM   #8
little_croco
Hong Kong
141
yes wor, I usually maintain them at around 40psi...
      02-11-2009, 09:52 AM   #9
william_cwl
william_cwl's Avatar
Drives: 2008 E91
2008 E91 323  [0.00]
2.7 bar is 39psi....
i guess it's a recommendation for very smooth roads and highway?
i dun think it's acceptable for rough roads like hk!
      02-11-2009, 07:43 PM   #10
Black Pig
Black Pig's Avatar
Hong Kong
Drives: E90 320i
I am using
Front: R19/35/235 - Hankook S1EVO 34PSI
Rear: R19/30/265 - Hankook S1EVO 36PSI
actually i am also wondering if my setting is correct or not........
      02-11-2009, 09:46 PM   #11
little_croco
Hong Kong
141
i will be a consideration of balancing off ride comfort and gas consumption
      02-11-2009, 11:29 PM   #12
kcleung
kcleung's Avatar
Hong Kong
Drives: E90 323
umm, after how bmw brag about their 50-50 weight ratio, they recommend different tyre pressures front and rear (also for 225/45 size)??
      02-16-2009, 10:46 AM   #13
ArktisE92
ArktisE92's Avatar
Hong Kong
Drives: E92 (Sold) / GT3RS / SLK55
I run 33 and 35 psi on my 19" 235/35 and 275/30 Mich PS2s (measured cold). But then I prefer a slightly heavier steering. The nose gets considerably lighter as you go from 32 to 34-35.
I used to run 32 all around to make the ride more comfy for the HK Island roads. But I went for the better handling after a while, comfort be damned
      02-17-2009, 12:11 PM   #14
dannygenio
Drives: 2008 E92 Flaming Red
lol tyre......
      03-20-2009, 12:57 AM   #15
K3VMO
11
Drives: E93 AW 335i
Okies,
After bouncing round a few garages and asking numerous mechanics... it turns out the general consensus is the settings I'm running: 36 PSi (Front) & 38 PSi (Rear).
You can tweak it +/- 2 PSi either way depending on your preference for handling.
