Is PIAA H11 & H7 compatible?
06-16-2006, 05:44 AM | #1 |
86
Rep 1,166
Just wondering if you guys can help identifying if these are compatibles?
15211 H11 55W = 110W output. Piaa Xtreme White Plus - Twin (2) Pack 17655 H7 55W = 110W output. Piaa Xtreme White Plus - Twin (2) Pack http://www.accessconnect.com/piaaaccess.htm
325i Arctics M-Sport, Gray Leather with Alu Trim, ///M DCT Paddleshift, ///M Gear Knob, BBS LM-R 19", Michelin PS2, KW V2, H&R Anti Roll Bars, BMW Performance Air Intake System, 3D Front Lip, ACS Roof Spoiler, OEM Boot Spoiler, Osram 6000K, Brex White Ring, PIAA 6200K HID Fog, PIAA License Plate LED, BMS Powerbox
06-16-2006, 06:55 AM | #2 |
Moderator
318
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
Got this information compilation from bavarian19 (AJ)....hope this helps:
H11 and H7 are not interchangeable, I think that's what you're asking. Voltagewise, you can use the H11 for fogs (55w is the correct voltage). I believe same case for the H7 bulbs (used in the halogens). 2006 BMW 325i, 325Xi, 330i, 330xi (With HID (high intensity discharge) headlamps) Low beam headlamp HID-D1S High beam headlamp (DRL) H7 Parking light 2825 Front turn signal 7507A Rear turn signal 7506 Tail light 7528 Stop light 7528 Fog/Driving light H11-55W License plate 6418 Front sidemarker 2825 Glove box 6418 Step/Courtesy light 2821 6411 6418 Trunk/Cargo area 6411
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
06-16-2006, 07:46 AM | #3 |
86
Rep 1,166
thanks mate. maybe i should have word it differently, just too lazy to type...hehe
i was asking if our stock OEM H11 and H7 could be replaced with the PIAA H11& H7 as shown in the above respectively. coz today went pass a shop that sells a generic brand H11 fog bulbs. the label reads 12v 80w ->100W. so i assume this is not compatible as it draws 80W from my car, and produce 100W blue-white light which i think its not advisable as i read in this forum that the stock H11 fog light bulbs are 55W. So i am looking for these. Now i found PIAA. Think i will order them.
06-16-2006, 07:51 AM | #4 |
Moderator
318
Rep 17,767
yep can't go wrong with PIAAs. And you are correct, you need a 55w voltage (final output doesn't matter) for the H11 bulbs to avoid the dreaded error message. I have verified this myself as I have swapped out my fog bulbs which are 55w-->100w.
As I mentioned, I am not sure about the H7s, I'd assume the same premise. GL, and please share results.
06-16-2006, 08:04 AM | #5 |
364
Rep 5,842
Drives: 2006 325xi
I am using the PIAA Fog light and i love them. they are bright, color is awesome, and No problems at all
06-16-2006, 09:33 AM | #6 |
86
Rep 1,166
thanks mds82 for sharing.
maybe you might want to post up a pic of your PIAA fog lemme have an idea how it looks!
