      12-16-2008, 08:05 AM   #1
Mark M
Mark M's Avatar
240
Drives: E30M3 E83X3 E90335D
KW Spring Rates ?????
Never used KWs before. Used ground control on a couple prior BMWs. Ground Control always let me spec the spring rates I preferred.
What are the KW spring rates? Can you spec your own spring rates, or locked into their standard springs? Thanks.
      12-16-2008, 11:34 PM   #2
rcracer_tx
55
Drives: BSM 135i
I believe they are progressive springs, and I have never heard of anyone having built to spec KW springs, but am not sure on this.
      12-17-2008, 01:30 PM   #3
karlenstein
15
Drives: BMW 130i
It depends... KW Clubsport range does not use progressive springs... they are linear.
Maybe you should point out which coilovers are you looking at...
KW Clubsports are also the only ones with adjustable front camber plates.
      12-17-2008, 08:31 PM   #4
Orb
No_Country
111
Drives: 335
KW2011 220-300 lb/in (Average 255 lb/in at max ride hight)
KW2012 570 lb/in
Orb
      12-18-2008, 07:35 AM   #5
Mark M
Mark M's Avatar
240
Interested in the V1 or the V2. What are the spring rates for those setups? Thanks!
1addicts
