      12-13-2008, 02:33 PM   #1
135forthewin
48
Drives: sideways
Rear Sway Install Time/Cost
Searched around, couldn't get a definite time required and/or pricing for the install of a rear swaybar.
It'd be H&R, but I doubt that makes a difference.
I'll probably be looking at $80/hr at a highly-recommended shop, so I'm curious how much it's gonna cost me.
So, professionally done, how long did your rear sway take to be installed and how much did it cost you?
Thanks!
      12-13-2008, 06:13 PM   #2
Templedogg
49
Drives: 135i, Trailblazer SS, 1934 PU
The shop I wemt to took one guy two hours to install both bars. The front only took him about 15 minutes!
      12-15-2008, 09:32 AM   #3
135forthewin
48
Drives: sideways
Thanks for the reply, so less than 2 hours for just the rear? Not as bad as I originally thought.
Templedogg, do you feel the understeer is reduced? The reason I'd be going with the rear-only is to reduce understeer, so I wasn't sure about ordering a front sway.
      12-15-2008, 01:22 PM   #4
Templedogg
49
Yes, the understeer was reduced some when I put on the Z1's and ditched the run-flats, and then again a lot more with the sway bars. It still understeers a little, but not nearly as much. I like it as it is now, very predictable and easy to power oversteer if needed.
I did both bars, but the front is very close to the stock one, when the weather is better and I can track the car again, I plan on putting the stock front back on to see if there is a difference in between sessions. I will report later the results.
1addicts
