12-11-2008, 01:52 AM | #2 |
NRA Life Member, BMW CCA 30 year member
180
Rep 2,614
The CDV, or, Clutch Delay Valve, eliminates slowish clutch engagement designed-in by BMW engineers(now, bean-counters?:iono, however, engine management is not affected. The clutch-response modification can transform your 1-Series into a proper German hot rod. What you do with/to your car is your decision, just remember, with every day, life presents all individuals with many choices.:wink:
Here's a DIY - http://www.1addicts.com/forums/showthread.php?t=6329
Resigned 1ADDICTS Moderator
To disarm the people is the best and most effective way to enslave them. George Mason |
12-11-2008, 02:25 PM | #3 |
137
Rep 1,450
CDV question
What exactly does this do ?
My clutch engages fast and solid so I guess it does more than just the mechancial action of the clutch. Does it affect how quickly the boost or timing is applied or something like that ? |
12-12-2008, 02:13 AM | #5 |
137
Rep 1,450
So I am guessing it is a mechanical action only then?
how can this help? if the clutch didn't engage fast enought it would slip and I do not experiecne that. Please can someone explain to me exactly how this works and benefits to car..... Cheers, Si |
12-12-2008, 11:52 AM | #6 |
Donkey Kong King
89
Rep 1,129
Ok, I'll try and explain. When you drive your manual and shift into 3rd gear, then release the clutch nice and smooth... you'll still feel a slight jolt through the car upon clutch engagement. This is because as your releasing the clutch pedal the Clutch delay valve has a restrictor inside of it which is controlling the pressure to the clutch for engagement. So basicly the clutch is either engaged or disengaged and no inbetween. Without the factory CDV (with a modified CDV), there is no restriction in the pressure (fluid). This results in more of a direct control of the clutch pedal release and clutch engagement. From what I gather, a modified CDV will allow a more possitive clutch feel and control while shifting.
I think the idea of the factory CDV is to help prevent the clutch from slipping (being partially engaged), however, this leads to some jerky shifts when driving the manual. Not really sure if anything I just typed makes sense... I have a modified CDV I'm installing on 23 Dec... I'll let you know how it works out.
[SIGPIC][/SIGPIC]
12-12-2008, 01:33 PM | #7 |
Joint Chiefs of Staff
4911
Rep 115,980
The modified valve is just a normal BMW valve which is hollowed out, which basically eliminates the valve altogether.
It makes a big difference on the feel and smoothness of your shifts. I don't think BMW should have used this on their cars. Also, its pretty cheap so can't really go wrong with trying one out Mike |
12-12-2008, 01:37 PM | #8 | |
12
Rep 403
It makes really good sense.
12-12-2008, 01:44 PM | #9 |
28
Rep 1,000
The stock CDV has a valve in it. This valve slows down the fluid flow when letting out the clutch. Remove the CDV. Push the valve out. It is very easy to do. Put the modified CDV back in. Less fluid restriction equals more clutch feel. Cost..a little brake fluid. JMHO
12-12-2008, 04:48 PM | #10 |
assistant to the regional manager
Rep 242
+1
No need to buy a "modified" CDV. I did this a few days ago. Took the old out, stuck a screw driver into the valve and tapped out the restrictor and reinstalled the CDV. Done, complete. Lost a couple drops of fluid, but did not need to bleed the lines. |
12-13-2008, 03:40 AM | #11 |
137
Rep 1,450
Thanks for the info, very helpful and I have a better idea of how this works now. What is the risk of needing to bleed the clutch, as I don't really want to get into all that type of stuff.
If I did this I would just want to swap over the valve with no risk of other stuff being affected. Also where is the CDV ? How easy is it to get to it ? How long does it take to do this MOD ? Thanks again in advance Si |
12-13-2008, 03:55 AM | #12 | |
180
Rep 2,614
12-13-2008, 10:02 AM | #13 | |
295
Rep 3,350
This device has been installed by BMW to reduce shock to the drive train, if fast shifting and high revving is the mode of operation (eg. racing). So - it is a trade off, do you want a little more clutch slippage (ie. wear) - or do you want more wear and tear on the transmission, drive shaft, rear differential, rear half shafts, etc? The clutch disk is not all that expensive compared to the other components, and it is the one piece that is designed with wear in mind. If you are going to race the car, and you don't care about warranty or costs anyways, so you might as well remove it or modify it to gain that extra 5-10% benefit in shifting. But if you plan to keep the car for several years, past warranty - and if you plan to drive it normally (most of the time) - I would say leave it in. |
12-13-2008, 06:11 PM | #14 |
21
Rep 513
IMO you wont do any harm by replacing the stock CVD with the modified one...^^^ i highly doubt allowing a lil more fluid to flow will cause any harm to be done to either the tranny or rear DIFF...
09 135i montego blue 6speed..RR catch can,CDV,DCI intakes,stett charge pipe and tial bov, the above mods are not installed on my car, i just want to seem cool
Devils own water/meth dealer-PM me for info former car/ 2001 audi TT ~290bhp :w00t: |
12-13-2008, 09:49 PM | #15 |
295
Rep 3,350
Only if you like to chirp the tires in first second and third a lot. Under normal driving, it should make no difference at all. Has anyone ever had an official explanation from BMW as to why they put this device in line with the clutch cylinder? It is curious that it is listed as a 'Lock Valve' in the real oem parts list. Lock what?
