12-07-2008, 01:08 PM | #1 |
Unindicted co-conspirator
66
Rep 1,734
Drives: to work, mostly.
Retrofit Homelink (BMW Universal Transceiver)?
Has anyone tried to retrofit the Homelink rear-view mirror? I'm not interested in getting the Premium package, but I would like this feature if possible. Is it just a matter of getting the rear-view mirror and hooking it up? Is this a big project?
Thanks |
12-07-2008, 06:05 PM | #2 | |
134
Rep 536
There is a retrofit harness. Installation is very straightforward. Check over on e90post for retrofit instructions. I have all the parts but doubt I will be installing an autodim mirror in my 1. |
12-07-2008, 06:29 PM | #3 |
66
Rep 1,734
I don't really care one way or another about the autodim mirror -- but if it's cheaper, can you get *just* a regular mirror (no compass or anything) with the homelink buttons? I assumed I'd have to get a 1-series mirror... And how much should I expect to pay?
12-07-2008, 07:02 PM | #4 | |
134
Rep 536
Retail on the UGDO mirror is $649. Though they pop up on ebay for a lot cheaper if you are cool with a used one. Retrofit supposedly requires coding which will add around $100. I am not sure if the coding is required or not though. I was told the coding was to correct issues with the auto wipers once installing the new mirror. The cheaper solution is to get the E46/E39 transmitter ($179 retail), mount it in the headliner and then wire it to ground and hot-switched power. You would still have the manually dippable mirror but none of the risk of the failing autodim mirror. |
12-08-2008, 06:34 AM | #5 | |
66
Rep 1,734
http://www.bmw330ci.net/projects/homelink.php This'll fit in the 1er? (Again, don't own one yet, just thinking prospectively....) |
12-08-2008, 07:37 AM | #6 | |
134
Rep 536
That’s the one. You wouldn’t be able to mount it in that location as that panel has a big control box on the back side of it. What options were you going to order on your car? |
12-08-2008, 07:56 AM | #7 |
torresfe
Rep 140
I actually did this retrofit to my wife 2007 X3 a few months back. The X3, 1 and 3 series used the same mirror. I pick mine thru e-bay for about $250.00 with compass, homelink and dimming feature.
You will need a 3 wires harness from the dealer for about $38.00. It can be found cheaper online. 2 of this wires will become grounds and the third one, switched power. Power can be obtained from the sunroof switch wire. If you take the e-bay route make sure to pick a mirror for a 2006 or newer car. 2005 and older is not the same mirror as the one series. NO DEALER CODING NEEDED! PM me if you want more info about it and a part number for the wirring harness. |
12-11-2008, 03:17 PM | #9 |
134
Rep 536
12-11-2008, 11:07 PM | #10 |
torresfe
Rep 140
When I took my wifes 2007 X3 in for service last week; The dealer gave me a 2008 328 sedan as a loaner. The mirror was the same shape as the one on my 135i and X3.
The 135 came with the homelink mirror; but I retrofit the one on the X3 with homelink and compass. when I have some time; I will put together some instructions on how to retrofit one of this mirrors on the 1 series. It is very simple. |
12-12-2008, 12:05 AM | #11 | |
8124
Rep 18,814
Drives: BMW
Flash2Pass Garage Door Opener System http://www.europeanautosource.com/pr...roducts_id=619 Take the $600 you save and buy some other mods for your 1er.
12-12-2008, 09:31 AM | #12 | |
Rep 78
12-12-2008, 09:44 AM | #13 |
131
Rep 1,540
Drives: '14 EBII M235i & '06 R53 GP
How about this:
$17.99 + $1.59 Velcro it in place inside your driver's door panel map pocket. And presto-chango, you gottum cheapie cheapie Universal Garage Door Opener. Did this in my MINI Cooper, works great.
12-12-2008, 12:22 PM | #14 | |
8124
Rep 18,814
Drives: BMW
Pin # 5 Small Brown Wire with Yellow stripe (+12V flash trigger lead) Pin # 2: Large Brown Wire (Ground) This picture would show placement: This picture shows some extra details of the install: Thanks to Zyphen for taking time to snap photos. A garage door opener clipped on your visor is equivalent to leaving your car keys on the driver's seat.
12-12-2008, 02:30 PM | #16 |
8124
Rep 18,814
Drives: BMW
Interesting, I can see them on my end.
This link shows placement: http://picasaweb.google.com/lh/photo...7A0gXvSbViRWPw This link shows some extra details of the install: http://picasaweb.google.com/lh/photo...27M7npzVPXwB6A Hope this works.
03-19-2009, 09:12 PM | #17 |
83
Rep 281
Possible retrofit
I have asked Jason @ getbmwparts.com to check into a retrofit kit for a homelink mirror. I wanted leatherette for the main reason it looks good at any mileage so I didnt get the mirror with Garage door opener. This is the same part used on the E90 retrofit so it could be the same procedure, plus you dont have to have the car coded after the retrofit .
Here is the part number along with its description 61120434330, description is Retrofit wife, review, electrocromat Here is realoem link to the part, believe its like $26 on getbmwparts.com, ask for Jason , he is very good to work with, very responsive, no days of waiting for an answer, hes quick, plus getbmwparts.com are approximately 20% off MSRP pricing which is 10% more than you can get with the BMWCCA discount plus depending on what state you live in, no taxes, another . http://www.realoem.com/bmw/showparts...=51&fg=95&hl=2 Last edited by damills; 03-19-2009 at 09:19 PM.. Reason: clarification, very very unclear |
07-13-2009, 05:14 PM | #18 |
AutoXer
34
Rep 683
Is the retrofit wiring harness real easy to install? Does it just hook into the sunroof control panel? If I find a good deal on one of thes UGDO mirrors on e-bay, I might try this out.
10-15-2009, 05:01 PM | #19 |
Rep 15
Just picked up an 08 3 series mirror with homelink and dimming to try a retrofit into my 135i. I assumed I needed the harness but a quick wire count of harness ends and it seemed like they matched up. I plugged the new mirror in and went to start her up....
and nothing... the car refused to recognize my comfort access key. Swap back the original mirror and it starts. Really? The rear-view mirror is integral to the car recognizing my keyfob?!?!!? Any thoughts or pointers? |
03-18-2010, 03:43 PM | #20 |
134
Rep 536
I just finished installing an autodim mirror from an MZ4 (much nicer mirror) in my 135i. The best DIY can be found here
A few notes. 1) Disconnect the negative battery terminal (and leave the trunk open)–this is in the pdf document but way at the front and you are playing with the car’s computer, you do not want to short anything. 2) The BMW retrofit harness has a solid brown ground lead going into the mirror side connector. When you open the stock mirror you will find that the solid brown would go to a brown/white wire location. Remove the solid brown wire from the retrofit harness, you do not use it. 3) No coding needed. |
03-18-2010, 03:44 PM | #21 | |
134
Rep 536
This is the retrofit wiring harness I used on my car. |
03-18-2010, 04:11 PM | #22 |
276
Rep 3,465
Drives: 997.2 GT3, '17 G30
Wheres the least cost place to order this mirror from?
ig: 0verrev
