      01-21-2026, 02:57 PM   #1
michalna102
Drives: BWM F40 23'
Angry F40 - Bluetooth problems - cancelling all calls
Hi, I have a strange problem with my 2023 BMW F40. The Bluetooth system automatically rejects all incoming calls connected to the phone (iPhone Air). In theory, everything works fine – Car Play connects immediately without problems, it works, apps works, calls can be made, Spotify works, and the speakerphone works when I calling from them. The only thing that doesn't work is answering the phone. The signal is like this: the phone rejects a call, voicemail goes straight to the connected phone when you call.
What I've done so far:
1. Tested on two phones that I'm sure are functional - the same behavior in both cases.
2. Tested the phones I tested on in two other cars and they work without any issues.
3. Reset the audio system by holding the volume button for about half a minute until the screen turns off and then restarts.
4. Tried turning the engine off and on several times.
Generally, after getting in the car and starting it, Car Play connects immediately as expected; everything works except receiving calls.
