10-19-2008, 12:03 AM | #1 |
11
Rep 817
Yet another RFT warning
I am sick of getting these warnings. Anyone else have this problem?
If this is going to be habitual I am going to ditch this POS car.
Gone: 2008 135i/2006 330i Arrived: 2006 997/Black/Sand Beige Leather/6MT/Sports Chrono Plus/19" Vorsteiner V-308s/Factory Nav/Sports Steering Wheel/Contrasting Mats/Heated Seats/Bose /V1/iPod adapter/Parrot Bluetooth/50% all around/Black "911" script/"Gundo Hack"/AWE black chrome tips/H&R adjustable front and rear sways/Rennline shift knob |
10-19-2008, 03:02 AM | #2 |
40
Rep 1,657
wtf are u talking about
"KOPEYKA" /// Titanium Silver / Black Leather / Gray Poplar / Sport Package / Premium Package / 6MT / Feb 08 Production |
10-19-2008, 04:06 AM | #3 |
NRA Life Member, BMW CCA 30 year member
176
Rep 2,614
^^Could you elaborate?
Resigned 1ADDICTS Moderator
To disarm the people is the best and most effective way to enslave them. George Mason |
10-19-2008, 05:16 AM | #4 |
What's FWD?
Rep 398
Lacrosse's probably talking about the low pressure warning on the run flats. If your tires are inflated correctly, your TPS maybe working improperly. Take it to the dealership for warranty replacement/repair.
10-19-2008, 06:24 PM | #6 | |
135 to 335 M Sport to X3 30d M Sport
164
Rep 1,788
Drives: 2018 X3 30d, optioned up!
Ummm, you're not serious, are you? (Just kidding)
2018 X3 30d, Carbon Black Metallic, M Sport Package, Panorama glass sunroof, Lumbar support, Instrument panel in Sensatec, Ambient Lightning, Harmon Kardon Surround Sound , Dynamic Damper Control
10-19-2008, 07:17 PM | #7 |
↓↓↓ Ex-Con ↓↓↓
34
Rep 1,874
Changing temperatures, like from summer to fall to winter, will have you adding air anyway since the pressure in your tire lowers as it gets colder. I check mine at least every two weeks.
The only time my TPMS warning came up was two weeks after I got my car and the temperature dropped 20 or 30 degrees outside. |
10-20-2008, 11:30 AM | #8 |
14
Rep 138
I often have problems when I park the car in the garage at night. I leave in the morning and park at work where the outdoor temperature is 30 or so degrees colder. If I go back out to the car after an hour or so, I'll get the light on. If I leave the car until lunchtime once its warmed up outside, then the car is just fine. I was originally under the impression that this system factored in temperature, but that's obviously not the case.
10-20-2008, 01:33 PM | #9 | |
81
Rep 1,075
One possible way to reduce false lights is to inflate your tires to 32 psi then calibrate the system to that pressure. AFter calibrating the monitoring system.. inflate the tires up to 36psi, or whatever the door data plate says. Of course, I haven't had a problem so I haven't tried it.
Ordered 4/7/08, Delivered 5/15/08, Sold, but not forgotten.
10-20-2008, 03:55 PM | #11 |
124
Rep 5,627
10-21-2008, 10:01 AM | #12 |
Senior Member
Rep 8
From what I've read, the benefits of Nitrogen over ordinary air are minimal - but if it's offered for free as in Costco, then why not? They typically install green colored caps if they use Nitrogen in the tires. My TPMS warning light came on two weeks ago and checking all tires showed that they were all 32psi - likely due to the drop in outside temperature. BTW, will the TPMS warning indicate which tire is the problem?
10-21-2008, 10:55 AM | #13 |
15
Rep 305
Don't all new cars have TPMS sensors now? So even if you ditch your current one, I don't see how it'd help you escape the warning lights when your pressure is low from temperature changes
Like others have said, could be a faulty sensor, no harm making a trip to the dealer and stealing some coffee.
Alpine White, Coral Red Leather, Sport Package, 6MT |
10-21-2008, 11:14 AM | #14 |
Ne Plus Ultra
88
Rep 264
Drives: Portimao Blue 2022 M240iXdrive
I believe when they drop 4 psi below the calibration point, the warning comes up. I get mine checked/filled at Costco with nitrogen and so far, I have not had any warning lights. Of course my car is stored in a garage and the temps her are warmer than the northern states some of our members live in. Also, you have to remember to recalibrate the TPS after you add any air.
10-21-2008, 07:26 PM | #15 | |
81
Rep 1,075
here's an idea if your tire pressure drops too fast
Sure enough.. After posting I went out to drive the car and my tire pressure light was on. The tires were all around 29-30psi, which I assume was due to the colder weather. I inflated them to 32psi and tried to calibrate but it only displayed the "resetting" message but did not reset after several minutes. I was in a hurry to go to lunch so I inflated them to 36psi and tried to reset it again. I got the same "resetting" message until I finally moved the car 10 feet or so. I'll have to try resetting it at 32psi again the next time. So if the light comes on when the pressure is 4 psi below calibration the light won't come on until they're down to 32-4 = 28psi. It would reduce nuisance warnings but I'm not sure it's really smart to let them get that low. Here's an idea if your tire pressure drops too fast: Use a socket and tighten the nut on the body of the valve stems. Don't overtorque them or you'll break something. One of mine did feel less tight than the other three. It was loose enough that I could tighten it using only my fingers on the deep well socket.
11-02-2008, 09:58 AM | #17 |
Rep 201
Hahaha, I think I believe you man. I already had my winters on order at the time thankfully, but right after I ordered I found a rear with at least 3 nails in it.....right after a trip to Home Depot. Sucked 'cause my order got delayed as the shop ordered the wrong rear tires so replacements were delayed, leaving me to drive my beater '94 Accord wagon around for a week and a half total.
135i ....
11-02-2008, 11:58 AM | #18 |
15
Rep 208
Alright come on guys, Natural Air (the stuff we breathe) is 78% N2, 21% O2, and 1% other gasses. So naturally if you use a regular air compressor your tires are going to be filled with 78% N2.
[SIGPIC][/SIGPIC]
09 135i Black Sapphire prem, sport, cold weather package hi fi, iPod, Nav Performacne: JB3 RR Oil Catch Can RR Stage II Intake RR Intake Plenum RR CDV BMW Performance Exhaust Cosmetics: CF Interior Trim M Door Sills GP Thunder 75K Black CF Ambergones |
11-02-2008, 12:31 PM | #19 | |
124
Rep 5,627
Tom |
11-02-2008, 02:45 PM | #20 |
Rep 41
I would have. You made the right choice!
2004 Lexus IS300
