      09-22-2008, 10:18 PM   #1
135-CS
16
Drives: EVO8,EVO9,E90,E82
Requesting Brake Fluid Bleeding Procedure
Hi I am just looking if there is any specific process to bleed our brakes. I have not looked yet where are the nipples for bleeding. But I assume there should be two of them in each caliper, can anyone confirm this? Should I use the same sequence as I sue on my Evolution, 1. Right Back 2. Left Back 3. Right Front 4. Left Front (Pump side)?
Thanks for the help!!!
      09-25-2008, 08:47 PM   #2
135-CS
16
Anyone!!!
      09-25-2008, 09:37 PM   #3
Lester
295
Drives:
Originally Posted by 135i-CS View Post
Anyone!!!
Did you do the CDV Delete? The trick is to not let the master cyl go dry. Pump and bleed, just like you said.
      09-28-2008, 03:49 AM   #4
CDR_UK
15
Drives: AW 1M
that's the order I did - works fine
      09-28-2008, 08:29 PM   #5
135-CS
16
Thanks For the Help Guys!!!
Search this Thread:
Advanced Search
1addicts
