      09-06-2008, 12:14 PM   #1
Krugar
Cruising Daily
11
Drives: 135i
2008 135i  [0.00]
Installing Tii SideSkirts
Not a very hard install, like always take your time and it'll turn out just fine. Will take around an hour or so.
I used a jack to get a little more access to under the skirt screws. You may or may not need to use one.
So we begin with a clean slate..
I started by removing the door sill, held on by 5 tabs..
After removing the door sill you will need to pop up the push clip pins like so.. and remove them (pin and the clip part)
Onto underside of the car you will need to remove the 8 or so Hex screws along the bottom of the sideskirt. (sorry for bad photo you can kinda of make them out)
after all the screws and push clips are removed you should be able to pull the sideskirt off. I worked it from the rear wheel forward. came off with no trouble.
then you should have a nice bare side area. Now if wanted you can clean the body under where the sideskirt was and wax it if wanted to put a layer of protection on there if so desired.
Now you need to align the new skirt and slide it into place, make sure the bottom of the skirt is tucked under the black underside mat thing. once its all lined up you may need to pop the top of the skirt into place a bit.
basically install is the reverse of removal. pop in the pins in the top of the sideskirt on the door sill and screw in the hex screws on the underside and finish by popping back in your door sills..
Finished product..
2008 BMW 135i - AR Catless DP - Agency Power Mids - Corsa Exhaust - KW v2 - Performance Side Skirts, Pedals, Steering Wheel, SSK. - CF Spoiler, Diffuser, Mirror Caps - Injen Intake - JB3 2.0 - CPE BOV Kit (HKS) - 6k HID AE - 6700k D1S - Evolution Racewerks FMIC -
croy0.00
      09-06-2008, 12:18 PM   #2
Krugar
Cruising Daily
11
Drives: 135i
2008 135i  [0.00]
Note: You dont need to use any of the hardware included unless you break a pin or something or you want to replace the screws and what not. I just reused the stock peices that came off.
Also a special thanks to Dan@UnitedBMW for the excellent prices and the paint work also.
More pics:
      09-06-2008, 12:45 PM   #3
EINSER M
EINSER M's Avatar
377
Drives: BMW i3 rex
awesome write up ill look it up if i end up doing those for sure!!!
      09-06-2008, 12:56 PM   #4
larryn
2146
Drives: '97 332ti, '21 X5 45e, '16 GT4
Great job! I added to the index of DIYs. Thanks.
Is that your real license plate?
      09-06-2008, 12:58 PM   #5
Krugar
Cruising Daily
11
Drives: 135i
2008 135i  [0.00]
Yes, thats 100% real :thumbup:
      09-06-2008, 01:06 PM   #6
larryn
2146
:thumbup:
      09-06-2008, 01:21 PM   #7
ruffstik
Pirate
ruffstik's Avatar
56
Drives: 2025 M2 G87 - on the list
2008 135i  [9.50]
Saweeet plates!
      11-05-2008, 02:12 PM   #8
miro2296
miro2296's Avatar
57
Drives: '08 Montego Blue BMW 135i
:thumbup:Great Job!!!! It looks pretty straight forward and looks great!!!:thumbup:
BMW 135i/6 Speed/Montego Blue/Formula One Ceramic Tint/JB4 G4/AA Sport Intercooler/19 inch Iconz 880Z(19X8.5 & 19X10)/PSS 225/35 & 265/30/E93 M3 front sway bar/TRW front and rear Control Arms/BMS Drop In Filter/Dinan Exhaust/BlackLines/Upgraded \\\M RSFB
      11-16-2008, 11:11 AM   #9
arrutled
arrutled's Avatar
103
Drives: Olsa
how the hell did you get the door sills off????????
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks!
      11-16-2008, 03:16 PM   #10
Krugar
Cruising Daily
11
Drives: 135i
2008 135i  [0.00]
you just gotta pull
      11-16-2008, 05:44 PM   #11
arrutled
arrutled's Avatar
103
Drives: Olsa
did that, and ripped the plastic pieces apart! its all good though I can fix it! thanks!
      11-18-2008, 12:01 AM   #12
arok
46
Drives: BMW F30 335i M-Sport
haha i ripped the damn tabs off the BMW sills too, i guess it's time for the ///M ones
2013 BMW 335i M-Sport
      02-26-2009, 04:38 AM   #13
cuizhuoyi01
EVO
Drives:
me too~~~~ sad. but i fixed them by a lighter. (maybe not strong as before)
135 EVO
      08-07-2009, 05:13 PM   #14
Justin(OKC)
Justin(OKC)'s Avatar
77
Drives: 1988 M3, 1990 M3, 1998 M3/4
1998 BMW M3/4  [10.00]
2011 BMW M3 Sedan  [9.28]
1988 BMW M3  [9.40]
1990 BMW M3  [10.00]
2008 BMW 135i - sold  [0.00]
2003 BMW M3 - sold  [0.00]
Thanks for the DIY. I only wish I had bought a tool to remove the door sills. Also, putting the black plastic piece in the vent hole was a bit of a chore. At first I didn't see that it clipped onto a plastic ridge. That tape is STICKY, especially if you treat it with the 3M plastic primer that came with the kit.
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black
1998 BMW M3 - Alpine White/Mulberry
2011 BMW 328i racecar - LeMans Blue/Black
      08-08-2009, 02:08 AM   #15
ki__
409
Drives: 19 M2C 6MT
Awesome DIY!
I would get it, but i dunno how it looks on a BSM car..it might not be noticeable =(
      08-08-2009, 07:36 AM   #16
Justin(OKC)
77
1988 BMW M3  [9.40]
1990 BMW M3  [10.00]
Originally Posted by BlacknRedi View Post
Awesome DIY!
You should go for it, it subtle, but very cool. The rear part of the skirt bulges out more so it's not like a the stock skirt with a vent in it.
      08-08-2009, 10:39 AM   #17
Smac355
40
Drives:
i put them on my BSM 135 about a month ago... its not a crazy difference since the piece is fairly subtle but it def add a touch of aggresiveness that really adds to the 135 look. i also got my dealer to paint the rear diffuser BSM while doing the skirts since (only $75 for the diffuser) which once again is subtle but kicks ass in my opinion, that gray is just no good. Ive been meaning to put some pics up so ill try and get my ass in gear.
Black Sapphire Metallic 135i/Coral Leather Interior/ Gloss Black Grills/20% tint/M door sills/Black 135i badge, smoked LED side marker, Dinan stage II , DINAN Exhaust, performance side skirts, performance shift boot/e-brake, pedals, carbon fiber wrapped interior
      08-08-2009, 10:46 AM   #18
Hind
///Mmmm
78
Drives: '09 BMW 135i
PIX!
Current: E90 LCI 335i JetBlack - BMS OCC, JB4 w/ E85, ETS Charge Pipe, Vishnu Catted DP
Retired:///E82 135i LeMans - 12.710 @ 108 MPH
Riss Racing OCC, Shadowline Grills, Magnaflow Axle-Back, JB4, ETS FMIC, BMS DCI, BMW Perf Sideskirts, BMS 12/10 Spacers, E93 Front Sway
PDC Flickr YouTube
      08-18-2009, 09:34 PM   #19
blklacker
blklacker's Avatar
50
Drives: 135i
how do you properly remove the door sills with out damaging them... I have to redo my passenger side skirt because I failed to put the little fake mesh insert before install. I already kinda weakened the door sills on the first run thru so any suggestions. BTW (Your opinions do u think the side skirts look better with the inserts or without??) ..
nvm found my answer!!
-135i BSM, CRBL ,custom front lip/Indianapolis red fade, blacked out tail lights/corner headlights, golf tee, BMS Air intake, SSTT, CF spoiler,Powdered coated OEM rims gunmetal high gloss,custom Rear diffuser Black/Indianapolis red fade
      08-18-2009, 09:35 PM   #20
blklacker
blklacker's Avatar
50
Drives: 135i
I like that!!
      08-30-2009, 07:31 PM   #21
IndyMike
IndyMike's Avatar
410
Drives: 11 VO 1 M/22 G42 Thundernight
Install accomplished on Saturday.
All-in-all took me about 4 hours to complete, but if you want to be quick about it it can be done in half that time.
As often mentioned already the toughest part is the door sills. I had a trim removal tool and I still wound up bending the plastic sill holders when popping the sill off.
Like Justin stated the black plastic rocker panel inserts were also a bit of a mystery, the grove in the insert corresponds to a ridge on the inside of the panel.
I'll post up better pics in the future.
Earth hear your Maker's voice, your great Redeemer own
Believe, obey, rejoice and worship Him alone
Cast down your pride, your sin deplore and bow before the Crucified.
"Before You, Lord, We Bow" - Francis Scott Key
      08-30-2009, 07:56 PM   #22
Justin(OKC)
77
1988 BMW M3  [9.40]
1990 BMW M3  [10.00]
nice job!! Is that Lemans/Lemon?
Search this Thread:
Advanced Search
1addicts
