09-03-2008, 06:15 PM | #1 |
Rep 45
Low oil after only 1800 miles.
On the way home from bringing my boy to football practice the oil light came on. I check the onboard computer in the driveway and it's below the min mark. It says +1 quart. The manual says not to drive the car more than 125 miles or engine damage may occur. Good thing I already made an appointment with the service department for a rattling noise. It goes in on Friday.
My thoughts on this are.... |
09-03-2008, 07:52 PM | #2 |
122
Rep 2,199
curious, did you do a hard/load break in?
or did you really baby the car? I'm at 1100 miles and mine still shows full, I did a hard/load break in, but did not ever go over 5500 rpm (still have not)
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
09-03-2008, 09:05 PM | #4 |
122
Rep 2,199
I can say for sure that some engines will not properly seat the rings unless they have a load put on them at break in, with motorcycles you simply go into a high gear and go WOT with it a few times to put high loads on the rings to seat them, or you'll end up with lots of oil burning
not sure if this is the same with cars, I've never gone into a really new engine to see how they were seating, or a turbo that already has much higher cylinder pressures
09-04-2008, 08:09 AM | #5 |
Santa Fe Concorso
103
Rep 2,984
And sensors can be inaccurate (sure wish this engine had a dipstick). Mine was registering Full with only 6 qts. after I changed the oil at 1500 miles. Added the 7th qt. and still registered Full. :iono:
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
09-04-2008, 02:11 PM | #6 | |
Rep 45
I'll have them check it out and I'll let y'all know what happens. Hopefully it's just innacurate sensor. The car was parked at an angle on a hill at the field so maybe that had something to do with it. The wife drives the car during the day so I'll see if the light came on again today. |
09-04-2008, 03:06 PM | #7 |
85
Rep 1,609
Very likely (90%), the oil sensor gone bad. If this is the case, you don't have to worry anything. Just take it back to the dealer for a replacement.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
09-04-2008, 03:19 PM | #8 |
58
Rep 1,201
Drives: 2015 M235i, 2017 Tundra
almost 4k miles no light for me..yeah yeah i dont need an oil change lecture
09-05-2008, 11:06 PM | #13 |
Ronnie
15
Rep 556
I had the same thing happen in my '06 323i, I thought something was wrong, but the car was pretty insistant that I chuck a litre in NOW. I did so, and never had another issue with it.
"Lucy" 128i / Sedona Red / Coral Red / Premium Package / Premium Sound |
