08-13-2008, 10:00 AM | #1 |
Mile High Member
Rep 109
Oil, Trans, and Diff Oil Change
Has anyone gone to a dealer to have these services done yet?
I'm looking to have this done as park of a "break-in" service. I know BMW won't cover it under their half a$$'d maintenance free program. I'm just looking to get not only an idea of cost but the time it took to complete the work. Thanks in advance!
I believe in Karma. That means I can do bad things to you all day long and assume you deserve it
08-13-2008, 10:37 AM | #2 |
85
Rep 1,609
I think the oil change is more important. I am looking to have mine done at 3000 miles myself.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
08-13-2008, 02:02 PM | #4 |
28
Rep 1,000
There doesn't appear to be a drain plug on the rearend. Pulling the cover will add to the expense. Be sure to take pictures if you have the cover off. We all would like to see what a welded diff looks like.
08-13-2008, 02:20 PM | #5 |
28
Rep 1,938
Really no reason to even begin to worry about the tranny and diff oil until at least Inspection 1 time. I believe every 30k miles is what the old "real" maintenence schedule called for.
The motor oil I'd dump at 1200 though. |
08-13-2008, 02:39 PM | #7 | |
Mile High Member
Rep 109
No problem...I'll take half a$$ maintenance program over a smart a$$'s opinion anyday. Opinions are like a$$holes actually, everyone has one. :wink:
08-13-2008, 02:58 PM | #8 |
Mile High Member
Rep 109
Motor oil will get changed out for sure. Wasn't sure about the others. Thanks to all those who replied with helpful information.
08-13-2008, 03:46 PM | #9 | |
Rep 54
Also I read somewhere that the rear diff is sealed, no drain or filler plugs there. |
