08-12-2008, 01:48 PM | #1 |
37
Rep 257
when does sh*t stop leaking onto rocker panels?
Does anyone else have the problem of a black goo leaking from the bottom of the doors onto the rocker panels about 18" back from the front wheel well (both sides)? Happens everytime it rains and everytime I was the car. Does this eventually go away? Seems to have an oil base, as it's harder to clean off than regular dirt.
"To add speed, add lightness." Colin Chapman
08-12-2008, 02:14 PM | #2 |
57
Rep 2,251
I wonder if it is the grease that is from your door hinges? Is it also under the door when you open it?
:iono:
BMW 135i/6 Speed/Montego Blue/Formula One Ceramic Tint/JB4 G4/AA Sport Intercooler/19 inch Iconz 880Z(19X8.5 & 19X10)/PSS 225/35 & 265/30/E93 M3 front sway bar/TRW front and rear Control Arms/BMS Drop In Filter/Dinan Exhaust/BlackLines/Upgraded \\\M RSFB |
08-12-2008, 02:19 PM | #3 |
Rep 205
I get this all the time too. It's been a few months since I've gotten the car, and it is occasional. It rained today, so I will see if it shows up tomorrow.
08-12-2008, 02:23 PM | #5 |
37
Rep 257
Not from hinges. It comes from further back along the door than that. I think it's maybe some kind of sealant from inside the doors themselves.
08-12-2008, 02:31 PM | #6 |
2146
Rep 10,176
Take a look at the black rubber scoop when you open your door, right up by where the B pillar would be (by the handle). There's a black scoop that diverts water along the rubber trim to a drop off point mid-way along the bottom of the door edge.
I don't think it's possible to get it to stop doing that, as it is a design queue to remove water from the door gap. I actually thought it was almost ingenious in it's simplicity, except for the incessant black line on my Alpine White car. |
08-12-2008, 02:35 PM | #7 |
37
Rep 257
Thanks, i will check that. Although i don't understand where it would pick up the fairly significant oily base along the way.
08-12-2008, 02:51 PM | #9 |
NRA Life Member, BMW CCA 30 year member
176
Rep 2,614
Might be vestigial cosmoline from the trip over. As it is now summer, ambient heat will soften/release the slimey goop. After nearly 5 months of ownership, I still get icky ooze from below the headlights.
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason |
08-13-2008, 12:08 AM | #11 |
163
Rep 4,311
Drives: Supercharged E90 M3
I HATE THE BLACK GOOP!
08-13-2008, 02:34 AM | #13 |
176
Rep 2,614
Is the goop we're speaking-of black or tan?
08-13-2008, 07:05 AM | #14 |
2146
Rep 10,176
It's a black streak of dirt on the rocker panel, because of the way the door jamb is designed to expel water. It's quite apparent on lighter colored cars.
08-13-2008, 07:10 AM | #15 |
103
Rep 2,474
yeah apparent after a week of driving! oh well! just another reason to give her a bath!
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks! |
08-13-2008, 10:49 AM | #17 |
Rep 242
Drives: 135i Black Sapphire Metallic
I get it too. Quik Detailer removes it better than a normal wash. I thought I had a scratch or gouge the first time I noticed it. Glad it was just something on the surface.
08-13-2008, 02:14 PM | #18 |
24
Rep 507
LOL!!! I thought I had gotten a defective car!! LOL!!! or improperly installed panels
Glad to see that I'm not the only one!!
2008 135i,Dinan Stage 2,Dinan Free flow exhaust.
08-13-2008, 07:22 PM | #22 |
34
Rep 531
4400KMs. About... oh... 12 car washes now (I don't drive it in the rain). Still there. Hate it.
