07-30-2008, 09:38 PM | #1 |
15
Rep 189
Anyone installed new pads on 135i?
If someone wanted to ... say... put track pads on for the weekend and buzz around for no good reason, but accidentally find themselves on a race course, how might said person perform a pad replacement on a 135i? Fronts only.
07-31-2008, 12:29 AM | #4 |
496
Rep 1,342
We changed pads (put in custom machined race pads from TMS) and definitely did not re-flash the ECU. We did not do anything to disable ABS either.
But we installed pads on all 4 corners.
07-31-2008, 10:20 PM | #7 | |
496
Rep 1,342
Which makes the rears really seem strange, because they do slide out the top after pulling the retaining pins.
08-01-2008, 07:28 PM | #9 |
15
Rep 189
I just put in track pads. Not too bad. You have to remove the pins holding the pads in place and remove two 10mm hex bolts holding the caliper to the brake assembly. The pads drop out from the bottom. You'll need to push the pistons back in, install new pads, then reverse. I'm trying the Cool Willy pads from Turner on 8/9. I toasted my stock pads after a track day a couple weeks ago. These pads along with motul brake fluid should do the trick.
