      06-07-2008, 04:58 PM   #1
imported_LiveFast135i
Drives:
Sway Bar Combinations
Tell us about your suggestions for sway bar combinations... Front only, rear only, or both? ... And your reasoning behind the decision. I know the topic is always brought up, but I feel as if this is needed.
      06-07-2008, 05:31 PM   #2
1er junkie
18
Drives:
I have read some posts that say they can only tell a difference in the rear, and the front is so minute they wouldnt even recommend changing it.
      06-07-2008, 07:22 PM   #3
Drives:
that's what i've read too, let's see what everyone else says, thnx junkie
      06-09-2008, 07:37 AM   #4
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Drives: '11 M-sport 328i, '13 X1 28i
In my experience, for non-adjustable setups on OE springs, the best results are obtained by using the same manufacturer's bars front and rear--they are designed to work together. In general, the same goes for adjustable bars but there is more leeway. All of the above is greatly effected by changing from OE springs to stiffer sets. Big increases in spring rates require less sway bar stiffness for most applications.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      06-09-2008, 07:45 AM   #5
larryn
2146
Drives: '97 332ti, '21 X5 45e, '16 GT4
Personally, I'm waiting for some adjustable setups to hit the market. I've had UUC Swaybarbarians in past BMWs and loved being able to dial them in to work better with whatever tire/damper combo I've chosen.
Who knows when we'll have an adjustable option though...
      06-09-2008, 10:47 AM   #6
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Hotchkiss is rumored to be working on a set of adjustables, and I bet UUC is also.
      06-09-2008, 10:51 AM   #7
larryn
2146
It should be fairly easy to make it up for the E82, since it should be the exact same bends, just with a shorter straight piece in the middle of each bar (for the slightly narrower car). We share most of the same suspension pieces as the e9x cars
      06-24-2008, 12:10 PM   #8
RedTRex
Digital Cerebrum
18
Drives: 05 330ci ZHP
2005 BMW 330ci  [0.00]
I was just researching this topic, I see by the dimensions our front track is 14mm (0.55") less than e92s - seems to me there would be enough slop in the foot long end links to bolt an e92 bar right up.......
I am really liking the Hotchkiss idea at 32mm.......
      06-24-2008, 12:28 PM   #9
RedTRex
Digital Cerebrum
18
e82 / e92 same sway!!!!!
Hey----Not sure if this revelation means anything but in realoem.com I just looked up the front sway bar on an e87 130i and compared it to an e92 128i........guess what! the part numbers are identical.:w00t:
I sent an email to Hotchkiss.
Search this Thread:
Advanced Search
1addicts
